Removing head from my h22a4
I'm removing my head cause my engine blew up
and after removing the cams I was removing the head I'm having an issue. I have not received the service manual in the mail yet but have enough knowledge to go as far as I have. not that I really know anything but I try.
What socket do I use to remove it? I tried a 14mm and it wont fit then a 15mm and it slips. What am I doing wrong besides not waiting for the service manual.
Thanks in advance for your time...
and after removing the cams I was removing the head I'm having an issue. I have not received the service manual in the mail yet but have enough knowledge to go as far as I have. not that I really know anything but I try. What socket do I use to remove it? I tried a 14mm and it wont fit then a 15mm and it slips. What am I doing wrong besides not waiting for the service manual.
I went and bought a 12point socket set and the 14mm socket worked this is why you wait for the service manual kids! That would have told me the bolt was a 12point not a 6 point. Moral of this WAIT FOR YOUR SERVICE MANUAL IF YOU HAVEN'T DONE IT BEFORE.
Stupid Berry!
Modified by Berry at 10:54 AM 9/16/2007
Stupid Berry!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dagle »</TD></TR><TR><TD CLASS="quote">uhh it might just be the english measurements...</TD></TR></TABLE>
What does this mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">The Prelude doesn't use any English sized bolts except the seat belt bolts.
IIRC, ARP head studs use a 9/16" 12 point nut, though. However, those obviously aren't Honda OEM.
really? i always used a metric 14mm 12pt on them, doh, i never really bothered to check if they were SAE size or not, just assumed it was metric
</TD></TR></TABLE>really? i always used a metric 14mm 12pt on them, doh, i never really bothered to check if they were SAE size or not, just assumed it was metric
You could be right. I can't remember. It's been 6 months or so since the last time I installed a head that used ARP studs. 9/16" is just a tad over 14mm, so if you used a 14mm, it's more than likely a 14mm 12 point nut.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Berry »</TD></TR><TR><TD CLASS="quote">i think he was talking about using a standard socket like a 9/16 or something </TD></TR></TABLE>
Metric is standard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theresyourproblem »</TD></TR><TR><TD CLASS="quote">
thanks, we were talking about...
</TD></TR></TABLE>thanks, we were talking about...
If you're working with Honda's, you need a good set of Metric sockets and wrenches. You can basically strip an entire car using a 10, 12, 14, 17, and 19mm socket/wrench.
BTW, you'll need the 12 point sockets for the clutch and flywheel bolts as well.
sayanything
Sep 9, 2010 10:37 PM
vectorsolid
86
Jul 14, 2008 09:49 AM
