Oil pressure switch
Old Sep 16, 2007 | 08:22 AM
kornerk12's Avatar
Default Oil pressure switch
Will a defective, damaged or disconected oil pressure switch cause starting problems ?
Old Sep 16, 2007 | 10:21 AM
117's Avatar
117
Default Re: Oil pressure switch (kornerk12)
No.
Old Sep 16, 2007 | 11:00 AM
kornerk12's Avatar
Default Re: Oil pressure switch (117)
are you positive ? Because looking at the wiring diagram it looks like it just connects to the light.
Also saying that the car wouldnt start without that sensor hooked up would be like saying a car wouldnt start without oil wouldnt it ?
Old Sep 16, 2007 | 12:41 PM
117's Avatar
117
AFAIK, the oil pressure switch only connects to the idiot light in the dashboard, so how could it possibly cause starting issues?
Old Sep 16, 2007 | 12:44 PM
kornerk12's Avatar
Default Re: (117)
yes thats what im saying.
Old Sep 16, 2007 | 12:58 PM
117's Avatar
117
Then why are you questioning my answer???
You asked if it would cause starting problems. I said no. Then you asked if I'm sure??? Why are you asking if I'm sure?
Old Sep 16, 2007 | 01:02 PM
kornerk12's Avatar
Default Re: (117)
im sorry i was misreading it. For some reason i took it as the car wouldnt start with those problems. I guess i might have alot on my mind.
ok so its only for the light ? and not an input to the pcm ?
Old Sep 16, 2007 | 04:29 PM
preludefien
Guest
Posts: n/a
Default Re: (kornerk12)
i would suggest leaving it unhooked...i did and i was loosing oil and my **** threw a rod
Old Sep 25, 2007 | 06:01 PM
trrbl1bmx's Avatar
Default Re: (preludefien)
i sense your sarcasm... oil pressure is one of the most important factors of your engine!!! DONT UNHOOK IT
Old Sep 25, 2007 | 06:12 PM
117's Avatar
117
If that oil pressure idiot light comes on, you're close to, if not already, f-ed. The light doesn't come on until oil pressure falls below 7.5 PSI.
Andre Dixon
Feb 17, 2016 06:50 PM
Mishako129
Oct 18, 2012 01:14 PM
19Accord97
Jan 30, 2012 06:25 AM
b18bye
12
Jan 11, 2011 07:37 PM
mmbaucom
Jan 28, 2006 10:14 AM
