Suspension & Brakes Theory, alignment, spring rates....
Wilwood Dynalite big brake front kit, with 11 diameter vented rotor (factory 240mm disc spindle civi
Old Sep 15, 2007 | 11:21 PM
x i b v r i a n's Avatar
Default Wilwood Dynalite big brake front kit, with 11 diameter vented rotor (factory 240mm disc spindle civi
i got them from a friend who deployed to irak
he used them before but he sold the crx
my question if any one has installed the same set up, can you give some info
how to install them, also what size and offset of rims to use with the set up?
thanks.
Old Sep 16, 2007 | 07:34 AM
Default Re: Wilwood Dynalite big brake front kit, with 11 diameter vented rotor (factory 240mm disc spindle
anyone?
Old Sep 16, 2007 | 12:57 PM
AMR Engineering's Avatar
Just go to wilwood.com and download there pdf file. The installation is very straight forward. If you have everything you need then it is a piece of cake. The bleeding can be a pain sometimes, but othe than that it bolts on fairly quick. There pdf file also has a illustration so you can see if you have all the correct parts. I was sponsored by wilwood about 5-6 years ago when my car was at Sema. Awesome brakes!!
Old Sep 17, 2007 | 04:59 PM
thanks for ur info, nice set up on ur ride too
i did went to wilwood site,
from my understanding it need clearence off set 45, but not sure if 15" wheels will be ok, and if 15" are ok its kinda hard to find 15 " wheels w/ off set 45, i've seen some mugens.
just wondering if anyone has pictures of this wilwood with 15" wheels set up
i really dont want to go 16".
Old Sep 17, 2007 | 05:09 PM
16" rim is the smallest you can fit, and if I remember right, not all 16" will fit either. The 15" I doubt will fit, but I may be wrong. My rotor is over 12", I think it's like 12.25" or something.
Old Sep 17, 2007 | 05:16 PM
Voyage34's Avatar
I only know of 1 15" wheel that will fit, made by Team Dynamics.
16" should give you better fit, but like AMR said not all 16" wheels will clear either. Enkei RPF-1 for example, does not IIRC
Old Sep 20, 2007 | 05:01 PM
.:Made in OC:.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote">I only know of 1 15" wheel that will fit, made by Team Dynamics.
16" should give you better fit, but like AMR said not all 16" wheels will clear either. Enkei RPF-1 for example, does not IIRC</TD></TR></TABLE>
15 TEAM DYNAMICS fit for sure? Any more info?
Old Sep 20, 2007 | 05:09 PM
Voyage34's Avatar
yes, Team Dynamics wheels fit, at least their Pro Race 1 model. I believe their 1.2 and 2 models do as well, their house design has tons of caliper clearance.
more info here
I was mistaken in my prior post, i commented thinking you were asking about the 12.2" wilwood kit which is very limiting as far as wheel choice, with the TD PR1 and PR2 being the only wheels Im aware of that fits.
Source here
Your options with the 11" kit are much more numerous
edited cause i spell like a n00b
Old Sep 21, 2007 | 07:53 PM
thanks for all your info guys
voyage, do u know who carry team dynamic wheels
and what offset should i use in 15" with the wilwood?
thanks.
btw im only running 11" rotor
Old Sep 21, 2007 | 08:37 PM
Voyage34's Avatar
Most of the cars in the first thread I lnked were running offsets in the +35 to +40 range which seemed to be issue-free.
as far as dealers, i know East Coast Tires has them, but I dont know how their prices are, it seems to me they were a bit high last i checked. Good-Win-Racing also does, and they are very reasonable price-wise. Brian is a miata guy so his site is primarily Mazda focused, but 4x100 wheels are 4x100 wheels. You might want to call and check on the center bore of the ones he carries since miatae have smaller hub bores.
And again, with the 11" kit you shouldnt have trouble fitting most wheels. If you decide to go another route besides Team Dynamics, Volk Rota etc should fit without much issue
Old Nov 4, 2007 | 06:31 AM
according to racing dynamic.com, their 14x7 +38 offseet would fit dynalite wilwood caliper with 11" rotor.
Sweet
h_block88
Aug 9, 2009 04:55 PM
huviduc
Feb 9, 2006 07:12 AM
CoreyR
Nov 28, 2005 05:48 PM
adeline
Sep 23, 2005 12:44 AM
tokisan
Suspension & Brakes
Sep 9, 2005 06:12 PM
