**** 1991 CRX SI - Turbo Built B16 - CLEAN ****
FOR SALE
1991 CRX SI
COLOR: WHITE (ORIGINAL PAINT)
MILEAGE: 122,740 (ORIGINAL)
PRICE: $10,000 U.S.
HISTORY:
THIS IS HONESTLY ONE OF THE CLEANEST AND FASTEST CRX'S YOU WILL PROBABLY EVER SEE ON THE STREET, DON'T LET THE STOCK APPEARANCE FOOL YOU. IT IS CURRENTLY TUNED TO 315HP BUT WILL SOON BE RETUNED TO AN EXPECTED 350HP. THE BODY IS FLAWLESS EXCEPT FOR 2 SMALL DINGS IN THE HOOD. ALL LIGHTS AND SWITCHES WORK, INCLUDING SUNROOF AND HEATER, NO AC. THE DRIVER SEAT IS TORN, BUT IS IN THE PROCESS OF BEING REPAIRED. CLEAN TITLE, NO LEIN HOLDERS. I AM THE SECOND OWNER, NEVER SMOKED IN. ALL THE WORK WAS PERFORMED BY AN ASE MASTER AUTO TECHNICIAN (ME) AND WAS DONE RIGHT. THE MOTOR IS SOLID, NO SMOKE OR ODD NOISES, COMPRESSION IS 155PSI (COLD) ACROSS THE BOARD. I HAVE EASILY $10,000 U.S. INVESTED IN PARTS ALONE, PLUS COUNTLESS HOURS OF WORK. I'M SELLING IT BECAUSE I SIMPLY JUST HAVE TOO MUCH MONEY TIED UP IN IT AND I WANT TO START ANOTHER PROJECT. WILL HAPPILY TEST DRIVE IF YOU CAN PROVE YOU ARE A SERIOUS BUYER.
ENGINE
-JE 9:1 PISTONS
-EAGLE RODS (ARP 2000 BOLTS)
-AEBS INTAKE MANIFOLD (POLISHED)
-STR 65MM THROTTLE BODY
-RC 750CC PEAK & HOLD INJECTORS
-AEM FUEL RAIL
-AEROMOTIVE 1TO 1 FUEL PRESSURE REGULATOR
-WALBRO 255 LPH FUEL PUMP
-GM 3 BAR MAP SENSOR
-REVHARD STAGE II TURBO W/CUSTOM COLD AIR INTAKE W/K&N FILTER
-CLEVITTE MAIN & ROD BEARINGS
-NUFORMZ BLOCK GUARD (TAC WELDED & DECKED @ MESA BALANCING)
-COMETIC .040" HEAD GASKET
-TODA BILLET OIL PUMP GEARS(84MM)
-FIDANZA ADJ. CAM GEARS
-CROWER STAGE II TURBO CAMS
-REV SPRINGS & TITANIUM RETAINERS
-REV 1MM OVERSIZED EX VALVES .5MM OVERSIZED INTAKE VALVES
-NEW VALVE SEALS & GUIDES
-PORT & POLISH PERFORMED @ EXTREME CYLINDER HEADS (PALM CITY)
-3" THERMAL RACING DEVELOPMENT CAT BACK EXHAUST (STAINLESS)
-ACT STREETLITE CHROMOLY FLYWHEEL
-SPEC STAGE II PRESSURE PLATE & STAGE III DISC
-DRIVESHAFT SHOP STAGE II AXLES
-MUGEN 176 DEG. THERMOSTAT & FAN SWITCH
-NEW FUEL FILTER
-B & M FUEL PRESSURE GUAGE
-NEXGEAR THERMAL BARRIER INTAKE MANIFOLD GASKET
-OBD0 B16A ENGINE
-NEW T-BELT,WATERPUMP& ALL NEW SEALS
-TURBO XS BOOST CONTROLLER (20 PSI)
-NO LIFT SHIFT & LAUNCH CONTROL
-NEPTUNE RTP ENGINE MANAGEMENT (LIVE TUNING & DATALOG)
-EXHAUST MANIFOLD & DOWNPIPE CERAMIC COATED
-MSD SPARK PLUG WIRES & NEW OEM WIRES
-FLUIDYNE RADIATOR
-FAL COOLING FAN
-NEW IDLE CONTROL MOTOR
-ARP HEAD STUDS
-ARP MAIN STUDS
-NGK 8'S SPARK PLUGS
-CUSTOM 3" DOWNPIPE
CHASSIS
-INTEGRA BRAKES IN FRONT W/ NEW INTEGRA MASTER CYLINDER & CALIPERS
-POWERSLOT ROTORS ALL AROUND
-RUSSELL STAINLESS BRAIDED BRAKE LINES ALL AROUND
-HAWK BRAKE PADS ALL AROUND
-ENERGY SUSPENSION MASTER BUSHING SET (RED)
-TOKICO STRUTS ALL AROUND(BLUE)
-GROUND CONTROL COIL IVERS ALL AROUND
-DARKSTAR RACING TRACTION BARS
-HASPORT MOUNTS & SHIFT LINKAGE
-FLAMING RIVER- BATTERY/ALTERNATOR CUT OFF SWITCH
-NEW SUNROOF PANEL (OEM)
-DC SPORTS BATTERY TIE DOWN W/ 3/8" BOLTS
-WHEELS LOCKS
-205/50-14 BFG DRAG RADIALS
INTERIOR
-PIONEER HEAD UNIT
-(4) ROCKFORD FOSGATE SPEAKERS
-(1) KICKER 10" SUB IN SEALED BOX
-ALPINE 700WATT AMP
-AUTOMETER EGI,MECH.OIL PRESS.,VAC/BOOST, & AEM WIDEBAND (MOUNTED IN GLOVEBOX)
-OPTIMA YELLOW TOP BATTERY W/TSUNAMI BATTERY TERMINALS (RELOCATED)
-NEW OEM TACH
-BOOMSLANG OBD0 TO OBD1 CONVERSION HARNESS
-SHIFTLIGHT MOUNTED IN A/C VENT
CONTACT INFORMATION
-OWNER- SHANE of ASAPerformance, LLC
-CELL- (954)775-4550 CALL ANYTIME, PLEASE LEAVE MESSAGE
-LOCATION- BROWARD COUNTY FLORIDA
-MYSPACE- http://WWW.MYSPACE.COM/ASAPERFORMANCE
ASAPerformance@GMAIL.COM
On to the pictures:
MORE HERE:
http://s103.photobucket.com/albums/m130/kami555/
Modified by OMG B16 at 10:23 PM 9/15/2007
1991 CRX SI
PRICE: $10,000 U.S.
HISTORY:
ENGINE
-JE 9:1 PISTONS
-AEM FUEL RAIL
-NEW FUEL FILTER
-OBD0 B16A ENGINE
-FLUIDYNE RADIATOR
-FAL COOLING FAN
-ARP HEAD STUDS
-ARP MAIN STUDS
-CUSTOM 3" DOWNPIPE
CHASSIS
-WHEELS LOCKS
INTERIOR
-PIONEER HEAD UNIT
-ALPINE 700WATT AMP
-NEW OEM TACH
CONTACT INFORMATION
On to the pictures:
MORE HERE:
Well 10k sounds a little steep but the car sure as hell looks nice and I'm sure it's worth it, good luck with the sale either way
nycludekid
Jul 24, 2006 07:03 AM
