CRX dash removal?
Is it true that you just remove like 3 screws to take the dash off? That doesnt sound right...
Here's where I saw it...
http://www.tamparacing.com/for....html
If that's not right, how do you take out the dash so I can remove the paint from it? Help, thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by denraweb »</TD></TR><TR><TD CLASS="quote">Is it true that you just remove like 3 screws to take the dash off? That doesnt sound right...
Well there "bolts" not "screws" and there is actually 4 of them if I am not wrong. You will have to remove the steering wheel and or lower the steering column as well as removing the center console, carefully detach heater control panel (impossible on OE crx units) and then of course unplug the few harness plugs from the under dash fusebox and a ground wire or two. It's been a few months since I swapped my CRX dash so I may have forgotten something but this is pretty much all you need to do to remove it. It's not that hard but it is more involved than just removing three screws.
</TD></TR></TABLE>Well there "bolts" not "screws" and there is actually 4 of them if I am not wrong. You will have to remove the steering wheel and or lower the steering column as well as removing the center console, carefully detach heater control panel (impossible on OE crx units) and then of course unplug the few harness plugs from the under dash fusebox and a ground wire or two. It's been a few months since I swapped my CRX dash so I may have forgotten something but this is pretty much all you need to do to remove it. It's not that hard but it is more involved than just removing three screws.
