GSR suspension on a 96 cicvic?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy »</TD></TR><TR><TD CLASS="quote">fronts yes. rears no.
rear sway will fit if you get si endlinks, d-brackets. someone correct me if im wrong. </TD></TR></TABLE>
this man speaks troof.
the lower fork on the rear shock wont fit the EK lca properly.
the front swaybar supposedly has clearance issues, though I dont know where.
The rear bar fits if you have D-brackets, and the mounting plates and endlinks from a 99-00 Si.
in the rears for the lower forks. i think you can use washers the shim. because the forks on the gsr shocks r wider then the rear civic lcas.
kinda ghetto n i wouldnt personally do it. but yeah.
donotenter
Oct 26, 2005 02:00 PM
jimmhatch
Jan 20, 2004 01:44 PM
