Hood Question
Old Sep 15, 2007 | 02:40 PM
DWeigs's Avatar
Default Hood Question
Well I am in the process of rebuilding the front end of my crx... I went and bought a hood from a junkyard and it was from a 91 civic. I was told the hood should fit but now its not lineing up properly!! This hood should fit right?? Thanks for your insight in advance!!
Old Sep 15, 2007 | 04:54 PM
DWeigs's Avatar
Default Re: Hood Question (DWeigs)
Bump!!
Old Sep 15, 2007 | 06:26 PM
subgeniusdude's Avatar
Should be lining up unless you have JDM headlights
Old Sep 15, 2007 | 06:29 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DWeigs &raquo;</TD></TR><TR><TD CLASS="quote">Well I am in the process of rebuilding the front end of my crx... I went and bought a hood from a junkyard and it was from a 91 civic. I was told the hood should fit but now its not lineing up properly!! This hood should fit right?? Thanks for your insight in advance!!</TD></TR></TABLE>
I am 99% sure it is the same hood but assuming it is, it still takes adjustment to make a different hood fit on your car. It's just a quirky thing like that, just make the proper adjustment to make it fit and it will be all good, you may need a body shop depending on how out of whack it is.
Old Sep 15, 2007 | 09:46 PM
DWeigs's Avatar
Well I did here that the crx and civic have a different front end.... So I have no idea what to think..... Ill get some pics up tomorrow!!
Old Sep 16, 2007 | 07:10 AM
Red_ED8's Avatar
Default Re: (DWeigs)
I think the only diff between the two is the fenders and bumper, correct me if I'm wrong. So the hood should be fine.
Old Sep 16, 2007 | 07:13 AM
Default Re: (Red_ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red_ED8 &raquo;</TD></TR><TR><TD CLASS="quote">I think the only diff between the two is the fenders and bumper, correct me if I'm wrong. So the hood should be fine.</TD></TR></TABLE>
x2
Old Sep 16, 2007 | 08:05 AM
BlueCrxNC's Avatar
It should fit fine provided it came off of a Civic Hatchback and that your car is straight. Civic Sedan and Wagovan Hoods don't fit properly. What exactly do you mean by it not lining up properly? You mean the gaps between fenders, or the latch mechanism, etc?
Old Sep 16, 2007 | 10:33 AM
DWeigs's Avatar
Bump for pictures...
Old Sep 16, 2007 | 10:44 AM
decateur's Avatar
work on your front end more and check the hinges
Old Sep 16, 2007 | 11:14 AM
jdm206's Avatar
Default Re: Hood Question (decateur)
is that a hood from a sedan? if it is dosent it hang a little to far from the head lights?
Old Sep 16, 2007 | 11:28 AM
wiZCo's Avatar
Stouts 'n' Scotch
All USDM 4th gen hoods are the same. From the placement of the hinges, however, it looks like they are from a sedan. (The sedan and HB/CRX hinges have different p/n's).
Put HB or CRX hinges on it, it should work then.
Old Sep 16, 2007 | 12:23 PM
markviiisvt4's Avatar
thats a sedan hood.
Here are the hood and hinge part numbers.
HOOD PART NUMBERS
88-91 HB.................60100 SH0 A01ZZ
88-91 CRX...............60100 SH0 A01ZZ
88-91 SEDAN...........60100 SH4 A02ZZ
88-89 WAGON..........60100 SH5 A00ZZ
90-91 WAGON..........60100 SH5 020ZZ
HINGE PART NUMBERS
88-91 HB RH...........60120 SH3 000ZZ
88-91 HB LH............60170 SH3 000ZZ
88-91 CRX RH.........60120 SH3 000ZZ
88-91 CRX LH..........60170 SH3 000ZZ
88-91 SEDAN RH.....60120 SH4 000ZZ
88-91 SEDAN LH......60170 SH4 000ZZ
88-91 WAGON RH....60120 SH5 000ZZ
88-91 WAGON LH.....60170 SH5 000ZZ
Modified by markviiisvt4 at 3:04 PM 9/16/2007
Old Sep 16, 2007 | 02:59 PM
DWeigs's Avatar
So basically I have the wrong hinges on my car...
Old Sep 16, 2007 | 03:45 PM
and hood
Old Sep 17, 2007 | 12:06 PM
DWeigs's Avatar
My old hood fit perfectly....
Old Sep 17, 2007 | 12:27 PM
IP RACING's Avatar
you have a crx. and you bought a sedan hood. sedan hood is different.
Old Sep 17, 2007 | 01:58 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (markviiisvt4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IP RACING &raquo;</TD></TR><TR><TD CLASS="quote">you have a crx. and you bought a sedan hood. sedan hood is different.</TD></TR></TABLE>
This is true. I got my P/N's confused. You definitely have a sedan hood.
cbp_crx
Feb 8, 2007 04:30 PM
dorkjoey
19
Sep 26, 2006 07:05 PM
B18aHatch
16
Feb 10, 2006 11:43 AM
91 HONDAsaurus rex
Aug 12, 2004 08:57 PM
egghead
Aug 14, 2002 10:09 AM
