distributor problem
Old Jun 17, 2002 | 12:44 AM
customx_'s Avatar
New User
Default distributor problem
lately i have been having distributor problems.
how can i tell when the coil, ignitor, cap, or rotor is about to go out? i already replaced the ignitor and cap. today while i was driving and at a constant speed, my tach needle suddenly bounced up and down, erractically. sign of something about to die?
Old Jun 17, 2002 | 06:53 AM
88_SC_CRX_Si's Avatar
New User
Default Re: distributor problem (mindtrix)
There is really no way of testing that stuff, unless you have the right equipment. Sooo, your pretty much left out on your own, of replacing peice by peice, until you hit it, otherwise it's off to a shop that can. Might try checking all your connections, etc...
Usually, a bouncing tach is a sign of bad igniter (as you probably already know...), could you have gotton a defective(sp) one, straight out of the box. Just a thought.....
[Modified by 88_SC_CRX_Si, 7:54 AM 6/17/2002]
Old Jun 17, 2002 | 04:06 PM
Chiovnidca's Avatar
Loose wire connectors on the igniter can cause that.
Old Jun 17, 2002 | 05:54 PM
sirminder's Avatar
i too had the same problem a day after my swap. i thougth it was my plug wires but when i saw the distributor, the bolts were all loose. turns out that i had lost one bolt, one was half way out and the other was barely tightened. thightened that bad boy down and it was all working fine.
Old Jun 18, 2002 | 03:28 AM
EE_Chris's Avatar
You can check the condition of the coil using a current probe and O'scope, but I doubt you have these [you would be checking the current ramp]
Do make sure all connections to the Ignitor are tight, as someone has already stated.
If the coil was on its way out, it can take the igniter with it. The primary coil resistance is very low, so there is a lot of current draw going through the primary AND the ignitor.
If you can get ahold of a DMM, test the resistance of the the windings....might give a clue.
Old Jun 18, 2002 | 11:30 PM
SpoolinEK's Avatar
could it be your alternator?? my bro had the same problem..
s13hero
31
Jun 17, 2016 06:43 AM
tigueremalo
Jan 28, 2007 11:24 AM
br1ev8
Dec 11, 2005 09:25 AM
92HB_HB
Feb 25, 2004 06:52 AM
blacksheep
Oct 13, 2002 10:08 PM
