HELP!
Old Sep 15, 2007 | 11:41 AM
E.'s Avatar
E.
Default HELP!
OKAY SO MY CAR IS MAKIN THIS WEIR NOISE WHEN IM GOING LIKE 40 TO 60 BUT WHEN IM GOING LIKE 70 TO 80 IT DONT MAKE IT THE NOISE COME LIKE FROM THE DRIVER SIDE AXLE I WAS THINKIN IT WAS THE half shaft or the axle it also make the clicking sound when i turn some times but it dont sound like the axle help me
Old Sep 15, 2007 | 11:56 AM
stock_honda_coupe's Avatar
Default Re: HELP! (E.T)
Axle shaft boot tore? Grease all leaked out? what kind of noise? do you feel anything in the steering wheel? Is your caps lock key broken?
Old Sep 15, 2007 | 06:19 PM
E.'s Avatar
E.
Default Re: HELP! (stock_honda_coupe)
I FEEL LIKE IT ON MY PEDAL AND LIKE A HELICOPER NOISE THAT IS COMIN FROM THE DRIVER SIDE AND IF I JUST TAP THE ACCELERATION PEDAL ID DONT MAKE THE NOISE AT ALL BUTIF I PUSH IT ALL THE WAY DOWN THE NOISE COME BACK WHEN IM DOING 40 TO 60
Old Sep 15, 2007 | 11:08 PM
Axle shaft or wheel bearing. Jack both front tires off the ground safely, and check for Side to side or up and down play in the wheel bearing area. Or, if the vehicle is safely lifted up, have a freind run it while in the air at the specified speeds and crawl under there and see if you can tell where the noise coming from. Safety is a must here.
But first fix your broken caps lock or shift key on your key pad.
Old Sep 16, 2007 | 08:04 AM
E.'s Avatar
E.
IIGHT THANKS MAN IM TRY IT
mikecp
Nov 15, 2011 06:53 AM
-faded-
Nov 7, 2007 11:26 AM
whp
Feb 3, 2007 08:08 AM
TylerW
Sep 5, 2005 09:39 PM
D16Z6_turbo
19
Mar 17, 2005 11:37 AM
