Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Misfire with lots of codes, please help
Old Sep 15, 2007 | 10:31 AM
VIPERBLUELX's Avatar
Default Misfire with lots of codes, please help
01 Civic non-Vtech 60K miles and it's got a misfire at idle. I've replaced all the spark plugs and I've got the following codes P1298, P0303, P0304, P0300. The last 3 look like misfire on 3 and 4 and a random cylinder misfire, but I have no idea what the P1298 is and I don't really know where to start to fix this problem. Any ideas?
Old Sep 15, 2007 | 11:03 AM
1llmatic's Avatar
New User
Default Re: Misfire with lots of codes, please help (VIPERBLUELX)
P1298 Electric Load Detector (ELD) Circuit Low Voltage
P0303 Number 3 Cylinder Misfire
P0304 Number 4 Cylinder Misfire
P0300 Random Misfire
http://www.tegger.com/hondafaq/error_codes.html
Old Sep 15, 2007 | 11:08 AM
Default Re: Misfire with lots of codes, please help (1llmatic)
Nice so should I start with replacing the coil pack on number 3 and 4 or look at something else?
Old Sep 15, 2007 | 03:38 PM
bravo831's Avatar
dot buy new coils switch the problem cylinders coil with a different one and see if ts misfireing in that cylider if it stays on the same one then its not the coil, after that do a compression test if its low the you got belt valves
Old Sep 15, 2007 | 05:00 PM
rushbuster70's Avatar
i had this same problem...replaced the coils and plugs...next thing i knew i had a blown head gasket...
Old Sep 18, 2007 | 12:39 PM
Default Re: (rushbuster70)
I cleared the codes and now it's coming back with all the same codes plus P0301 for cylinder 1 misfire. I know all 3 coils can't be going out at 60K miles.
Old Sep 18, 2007 | 12:47 PM
thinknology's Avatar
Default Re: (VIPERBLUELX)
If your getting an ELD code try checking it out... It's tied in with alot of things... I sound like an idiot, worth an investigation though,I dunno... *walks out of thread*
Old Sep 18, 2007 | 02:04 PM
funz0rzies's Avatar
I've had the misfire codes on 1-3 along with random misfires. I replaced the spark plugs and it eventually went away.
My problem seems to happen ONLY during cold weather. It happened last winter and recently when I left my car outside overnight.
gohonda
May 12, 2019 05:44 PM
mcannon
Nov 30, 2014 10:54 AM
DarkBB4
Jul 30, 2014 11:44 AM
stuckinkaos
19
Sep 3, 2013 09:52 AM
all-mtr-teg
26
Nov 29, 2007 08:33 PM
