Any turboed hf's????????
yea, that would be pretty stupid, lets turbo my hf so it can keep up with a 92-95 civic si!!! hehe
you might get 100 hp TOTAL with a bolt on turbo kit, if they make one!
I would turbo it. Why you ask? To learn. Build yourself a homemade kit. Then, when that motor goes. Hopefully you will have learned enough to know why it went, and how to prevent it on your next motor. Then, buy a new motor, like the ZC, and use that same kit on that motor. Then away you go.
[Modified by kbslacker, 7:48 AM 6/17/2002]
the actual engine wouldn't take the boost. it would probably break the moment you start the engine. HF parts are light but, never have been known to be strong.
actually i have had my motor turboed stock hf @ 11psi for 2 weeks now and i beat a crx w/ a B16 in it. ts actually holding up fine i have the wastegate acutator disconected, im tryin to blow it up. the only thing that has gone is my clutch its slipping pretty bad
