WTF is going on here
Old Sep 15, 2007 | 09:19 AM
turbozcteg's Avatar
Default WTF is going on here
so after i go threw all my trouble shooting :ie, fuel spark timing and compression
and so i thought my ecu was bad but i pull the carpet down and look at my ecu, the key just happens to be on and i see it blinking really fast then a pause so i turn the key off and then back on and i get 8 flashes and then 16 flashes
my car being a obd-0 dual point d15b1 with the a6 head
i thought my ecu was too retarded to give off codes ???
but when looking up the codes 8 is topdead center sensor
and 16 is injectors
so my question is where the hell is the topdead sensor
and i have already changed injectors and there still giving off a code
what the hell do i do to get my car running
help please
my car has been down for 2 weeks now and riding the bus is mad gay
thanks h-t members
~jake
Old Sep 15, 2007 | 09:36 AM
hondacivic90zc's Avatar
Default Re: WTF is going on here (turbozcteg)
what ecu are you running? I know the top dead center sensor is in the distributor but i thought that was only for the mpfi so that the ecu knows when each piston is at top dead center? Maybe somebody else can clarify this. Also have you tried disconnecting the battery, waiting about a minute, and then connecting it again (this will reset your ecu and any codes it has)?
Old Sep 16, 2007 | 09:47 AM
turbozcteg's Avatar
Default Re: WTF is going on here (hondacivic90zc)
yeah ive had my battery off for like 6 hours and still wont reset
i am running the pm5 dual point ecu
and its comming up with code 8 and 16
if the dual point codes and the multi codes are different could someone please let me know what im sopposed to be looking for
DIYaccord
Apr 13, 2006 01:06 PM
the.hamburglar
Jul 29, 2004 07:44 PM
crxtreme27
Jul 1, 2003 04:30 PM
kim_2_da_chee
May 30, 2003 06:18 PM
