1990 civic si with problems....need help
not my car but im workin on it.....It gots a b16a swap...so what happened was the dude that owns the car was driving with no battery stay and .....guess what...battery tiped over and grounded out now car wont start...it starts with starter fluid then dies out....fuel pump works can hear it pumpin away...got spark and as far as i no got fuel to motor...wut else could be wrong.... help plz!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockofcali »</TD></TR><TR><TD CLASS="quote">done all that no fuses were fried sum little homemade bs ground wires were torched and thats about it no visible damage to the harness</TD></TR></TABLE>
Ground wires are important. Did you replace the ones that were fried?
Are there any CELs?
Are there any CELs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockofcali »</TD></TR><TR><TD CLASS="quote">these ones were not important they were as thin as speaker wire... the main ground is enough to start it and it was fine</TD></TR></TABLE>
OK, whatever you say. They're still important.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
OK, whatever you say. They're still important. </TD></TR></TABLE>
Not if the owner added rice straps though.....
Grounding out the battery with the cables on can fry the ECU.....
i no thats wut im afraid of...shouldnt the ecu fuse go out b4 the ecu gets messed up...and would it start with a bad ecu? bc it starts with starter fluid and idles but once i stop puting starter fluid it dies out
I just got my 1990 civic si legit today smoged, registered, and new pipes. Well i was driving went over a bump slow as possbile. The battery wasnt strapped down. It turned over on its side and shorted out the battery and the fuel pump. the ecu fuse is fine as well as all the others. The fuel pump was ran right to the ecu and a simple kill switch was wired to it. Relays never worked so i guess the guy ran it stright to the ecu. I replaced the fuel pump, it primes over and everything still no fuel getting to the motor. all hoses are in the proper place. The ecu is flashing once and than 3 secs later 7 more times. o2 sensor, and i think tpc. But thats obd1 the harness and ecu is obd0(b16ecu). The motor is a 2nd gen jdm b16a. The car starts up with starter fluid and dies out when not being sprayed with the fluid. So that simple test imo means its a fuel problem?? or maby someone can give me some help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce »</TD></TR><TR><TD CLASS="quote">I just got my 1990 civic si legit today smoged, registered, and new pipes. Well i was driving went over a bump slow as possbile. The battery wasnt strapped down. It turned over on its side and shorted out the battery and the fuel pump. the ecu fuse is fine as well as all the others. The fuel pump was ran right to the ecu and a simple kill switch was wired to it. Relays never worked so i guess the guy ran it stright to the ecu. I replaced the fuel pump, it primes over and everything still no fuel getting to the motor. all hoses are in the proper place. The ecu is flashing once and than 3 secs later 7 more times. o2 sensor, and i think tpc. But thats obd1 the harness and ecu is obd0(b16ecu). The motor is a 2nd gen jdm b16a. The car starts up with starter fluid and dies out when not being sprayed with the fluid. So that simple test imo means its a fuel problem?? or maby someone can give me some help!
"I just got my 1990 civic si legit today smoged, registered, and new pipes. Well i was driving went over a bump slow as possbile. The battery wasnt strapped down. It turned over on its side and shorted out the battery and the fuel pump. the ecu fuse is fine as well as all the others. The fuel pump was ran right to the ecu and a simple kill switch was wired to it. Relays never worked so i guess the guy ran it stright to the ecu. I replaced the fuel pump, it primes over and everything still no fuel getting to the motor. all hoses are in the proper place. The ecu is flashing once and than 3 secs later 7 more times. o2 sensor, and i think tpc. But thats obd1 the harness and ecu is obd0(b16ecu). The motor is a 2nd gen jdm b16a. The car starts up with starter fluid and dies out when not being sprayed with the fluid. So that simple test imo means its a fuel problem?? or maby someone can give me some help!"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce »</TD></TR><TR><TD CLASS="quote">But The fukin pump is workin we re not having problems getting the fuel pump to work its getting the ****** fuel to thr motor! <3 uncle</TD></TR></TABLE>
Obviously the main relay is working. The main relay sends power to the fuel pump and the ECU. You've determined that the fuel pump is running - but that doesn't mean the ECU is working, because the injectors aren't spraying. The problem must lie between the ECU and the injectors.
That idiot is lucky the battery didn't start a fire and burn the car down when it tipped over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jayponce »</TD></TR><TR><TD CLASS="quote">The fuel pump was ran right to the ecu and a simple kill switch was wired to it. Relays never worked so i guess the guy ran it stright to the ecu. I replaced the fuel pump, it primes over and everything still no fuel getting to the motor. all hoses are in the proper place. The ecu is flashing once and than 3 secs later 7 more times. o2 sensor, and i think tpc. But thats obd1 the harness and ecu is obd0(b16ecu). The motor is a 2nd gen jdm b16a.</TD></TR></TABLE>
Wow, what a clusterf*ck.
Good luck with that hacked together piece of ****. Why do people ruin their cars by messing with the wiring? Not only does it serve no purpose, it also makes it impossible to follow electrical troubleshooting procedures outlined in the factory service manual.
The car is getting spark but no fuel (the fact that it runs on starter fluid indicates that).
If i would known that the pump was ran to the ecu i wouldnt have bought the car! Now im fucked. I just spent $600 on the car yesterday smog,reg,pipes, tuneup! I really need some detailed imformation on how i can check if the ecu is bad/good, if the injectors are getting power and how should i go about this.(shitty wiring)
The fuel pump primes when you first turn on the key right? but does it run while cranking? check to make sure its getting 12 volts while cranking not just when you first turn the key. if it is then the injectors are not working( which can also be ECU). if its not getting 12 volts then its a ECU/messed up wires issue. every thing will seem to come back to the ECU or that messed up wire mess the last owner did. can you get a loaner ECU to try?
