magnaflow exhaust weld broke
Old Sep 14, 2007 | 06:11 PM
93civichatchinky's Avatar
Default magnaflow exhaust weld broke
ok i allready had a magnaflow cat back exhaust installed on my 04 ep3 today i installed a magan ss header and test pipe took it for a spin and it got really loud looked under the car and the weld on the mid pipe broke! the one that connects to the test pipe. the flange with 3 bolts is still connected to the test pipe but the weld holding the flange to the start of the mid pipe is broken. has anyone else had this problem? whats the best way to fix the problem so it does nt happen again?
Old Sep 14, 2007 | 06:17 PM
WhiteOnRice's Avatar
Get it replaced by Magnaflow. I've had mine with no problems for a long time. If the header doesn't have a flex-pipe, that's your problem.
Old Sep 14, 2007 | 06:25 PM
no flex pipe same as stock with the spring bolts i cut the springs down as described in the oct 07 sport compact car so the springs wouldnt bottom out
Old Sep 14, 2007 | 06:57 PM
Sounds like you just got it. Call Magnaflow up. Their parts don't normally do that.
Old Sep 15, 2007 | 07:06 AM
dx_rex's Avatar
Default Re: magnaflow exhaust weld broke (93civichat*****y)
this happened to mee too... only it was on my megan ss test pipe and i dont think i can weld ss .. should have done it right the first time.. rh+esmm
Old Sep 15, 2007 | 12:46 PM
I didn't have ESMM and it worked fine. I got a torque dampener but the Magnaflow was taking the engine movement for a couple years before that.
Old Sep 15, 2007 | 03:27 PM
Tyte-S's Avatar
Default Re: (WhiteOnRice)
As long as you got it from one of their dealers, Im sure it can be replaced.
Old Sep 15, 2007 | 03:56 PM
dx_rex's Avatar
i plan to get a rh... already got a tq dmpener.. that should be alright???.... i just dont want aything to happen again.. besides a rh will accent my T1R catback nicely.. i hope
Old Sep 15, 2007 | 04:25 PM
Default Re: (dx_rex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dx_rex &raquo;</TD></TR><TR><TD CLASS="quote">i plan to get a rh... already got a tq dmpener.. that should be alright???.... </TD></TR></TABLE>
Should be good w/ or w/o the TD.
90RioEF
Feb 6, 2014 06:58 PM
norcalB18
Sep 24, 2009 12:19 PM
NsX_CrX
May 21, 2006 01:41 AM
Del Slow
Apr 18, 2005 01:51 AM
G6-Civic
Oct 6, 2004 03:22 PM
