Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
knocking or rumbling
Old Sep 14, 2007 | 04:42 PM
MarkLBailey's Avatar
Default knocking or rumbling
My '03 Civic hybrid makes a knocking or rumbling sound when taking off from a standing stop. This noise/sound only lasts for a second. The noise seems to be coming from the right front wheel area. If excelerating lightly, the noise/rumble is slight. If excelerating harder, the noise/rumble is louder and more pronounced.
Any ideas?
Thanks....
Old Sep 14, 2007 | 04:55 PM
mikelax125's Avatar
* B A N N E D *
Default Re: knocking or rumbling (MarkLBailey)
bad tires. bad alighnment i mean really bad, bent rim, buble in the tire, bent controle arm. i could probably think of a hundred things sadly. my gusse is bent rim
Old Sep 14, 2007 | 05:06 PM
honda917's Avatar
like a hard vibration , how many miles it might still be under warrenty, either the start clutch, once i saw it was a motor mount
Old Sep 14, 2007 | 06:49 PM
Default Re: knocking or rumbling (honda917)
Several years ago, My Son curbed the right front wheel, real bad. New rim, several new suspension and alignment parts.
Vehicle ran great after repairs. This is something that just developed within the past 6 months.....Someone mentioned CV joint????
Old Sep 14, 2007 | 06:54 PM
Not a vibration per say. Makes the sound as if you were driving over a rumble strip, just a quick second as you start rolling from a stop.
The vehicle, which is an auto has 42K miles and is out of warranty.
Someone had mentioned that possisbly a CV joint was the problem.
Old Sep 14, 2007 | 07:19 PM
honda917's Avatar
your car has a cvt trans which has a start clutch in it i have seen a lot of them go bad it only happens when leaving a light for about 1-3 sec and goes away like nothing ever happened until the next light, like a momentary judder below 15 mph from a stop covered 7 year 100,000 miles just call and ask a dealership if i am wrong sorry
Old Sep 16, 2007 | 04:46 AM
Thanks, I'll call the dealership on Monday...
ramboPandA
Mar 23, 2015 08:41 AM
EKsedan715
Nov 30, 2010 02:06 PM
k20eklipse
Aug 3, 2010 08:40 PM
ekinshuya
May 1, 2008 02:09 AM
MyLittleRedCar
Oct 20, 2003 10:48 PM
