Choosing the right Honda bearings
Old Sep 14, 2007 | 03:50 PM
vinuneuro's Avatar
Default Choosing the right Honda bearings
How do you normally go about doing this? I can't imagine the marks on the crank and block being too useful after many many thousand miles. Both the journals and bearings would have worn some right? So I don't know what the original clearance in the motor was, and checking them now won't accomplish anything either.
So how do I get the right ones before checking the clearance? Buy one of each color and find the right combination for each journal until the spec is right? Then reorder the right quantity of the bearings I need? Is there a more efficient way to get the right clearances? This is for an H22, so I'll most likely have to mix colors per the helms chart.
Thanks.
Old Sep 14, 2007 | 04:00 PM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: Choosing the right Honda bearings (vinuneuro)
Yes, you can read the codes on the crank and block after many many thousands of miles.
Or you can buy a inside/outside mic that will read ten thousands.
Or you could take it to a machine shop.
Old Sep 14, 2007 | 04:14 PM
vinuneuro's Avatar
Default Re: Choosing the right Honda bearings (mar778c)
I meant that knowing what bearing colors were originally used won't be of much help because the journals must have worn some. So I'll most likely need different color bearings than were used from the factory. Am I wrong?
Old Sep 14, 2007 | 04:24 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Am I wrong?</TD></TR></TABLE>
Pretty much. The original size bearings should work perfectly. Crank journals don't wear much. They are much harder than bearing material.
Old Sep 14, 2007 | 04:34 PM
mar778c's Avatar
Community Builder
Very much so. Journals should have almost no wear.
Old Sep 14, 2007 | 04:53 PM
vinuneuro's Avatar
Default Re: Choosing the right Honda bearings (b19coupe)
Thanks guys.
Prudz_lude
Jan 11, 2010 08:14 PM
milton
May 8, 2005 02:09 PM
jdmhatch94
Sep 13, 2003 02:03 PM
super laubo
Mar 24, 2003 03:15 PM
DamonBoost
May 14, 2002 10:52 AM
