which supertech valvetrain for blox b's and skunk stage 3's
with the blox b cams, it has a 12.6 lift.
supertech 2d kit has a max lift of 12.5, would would that go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiB16A »</TD></TR><TR><TD CLASS="quote">with the blox b cams, it has a 12.6 lift.
supertech 2d kit has a max lift of 12.5, would would that go</TD></TR></TABLE>
I think the Blox Bs have a lift of 12.3mm ...
You will be ok with the Supertech 2D Kit..
I believe the stiffer spring rates would promote more ware & stress on the cams. I personally would run the softest spring the manufacturer recommends. That is just my own opinion, no fact & I may be wrong. What does everyone else think?
thanks for your input, i dont know myself either hence this is why thread is posted. Thanks for posting, anyone else?
stiffer is not always the answer and the better choice in some applications. you dont want it to TOO stiff, that can also rob power and of course not good for the motor overall.
the 1002d should be fine for all those camshafts.
1002d is for turbo app, all motor i believe is the 100d correct me if im wrong here.
I'm running crower stage 2 cams with 100dr kit, you think I will be ok?
Here I found specs:
Supertech B-Series Valve Springs PN SPR-H1002D-KIT
Variable or Linear: Linear
Seat Pressure: ???
Max Lift: 12.5mm
Coil Bind 19.5mm
Pressure @ 12mm/.472" lift: 190lbs
Supertech B-Series Valve Springs PN SPR-H100DR-KIT
Seat Pressure: ???
Max Lift: 14mm
Coil Bind ???
Pressure @ 14mm/.551" lift: 266lbs
Modified by toolfan020 at 9:21 AM 3/11/2008
Here I found specs:
Seat Pressure: ???
Max Lift: 12.5mm
Coil Bind 19.5mm
Seat Pressure: ???
Max Lift: 14mm
Coil Bind ???
HTDragazn
Nov 29, 2002 02:51 AM
