Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Aftermarket Fuel pressure regulator
Old Sep 14, 2007 | 10:57 AM
DJaeMac's Avatar
Default Aftermarket Fuel pressure regulator and fuel rail
i need help on where i could buy an aftermarket fuel pressure regulator and an aftermarket fuel rail
i searched, but i couldn't find any specific ones for the d17
any info would be helpful.
thanks
Old Sep 14, 2007 | 11:06 AM
toyomatt84's Avatar
Sanji
There's really no car-specific FPR's out there. They're pretty much universal.
Old Sep 14, 2007 | 05:28 PM
DJaeMac's Avatar
Default boosting question
is it mandatory to upgrade the fuel pressure regulator on a boosted d17?
i've upgraded fuel pump and injectors, but do i have to upgrade the FPR?
Old Sep 15, 2007 | 02:34 AM
tran1's Avatar
i dont know i guess it depends how much your trying to boost im boosting the zc @ 7psi with a walbro and rc injectors.
Old Sep 15, 2007 | 09:34 AM
Curiouz_G's Avatar
returnless fuel system
Old Sep 17, 2007 | 06:18 PM
DJaeMac's Avatar
Default aeromotive fuel pressure regulator
would this FPR fit my d17 engine?
http://www.aeromotiveinc.com/p...od=10
Modified by DJaeMac at 7:28 PM 9/17/2007
Old Sep 18, 2007 | 12:08 AM
Hawkze_2.3's Avatar
Default Re: aeromotive fuel pressure regulator (DJaeMac)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJaeMac &raquo;</TD></TR><TR><TD CLASS="quote">would this FPR fit my d17 engine?
It's universal...it doesn't fit anything. If you're boosting your car you might want to learn about stainless steel lines and AN fittings.
That regulator will have to be custom mounted, which people do quite often...
Old Oct 3, 2007 | 10:46 AM
lee0149's Avatar
Default Re: Aftermarket Fuel pressure regulator and fuel rail (DJaeMac)
from what i think y
ou dont need a fancy one just get BLOX of B&M reulator
Old Dec 2, 2007 | 11:45 AM
RISRdotNet's Avatar
d17 FPRs are located in the fuel tank, it's a returnless system, you have to get a d16 fuel rail and run a aftermarket fuelpump, fpr, fuelrail, and return line, writeups on civicforums.com
Old Dec 2, 2007 | 03:39 PM
theciv's Avatar
Default Re: (RISRdotNet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RISRdotNet &raquo;</TD></TR><TR><TD CLASS="quote">d17 FPRs are located in the fuel tank, it's a returnless system, you have to get a d16 fuel rail and run a aftermarket fuelpump, fpr, fuelrail, and return line, writeups on civicforums.com</TD></TR></TABLE>
very good information. thanks. im looking into this. will the fuel rail bolt right up?
existanzcivicb20
Apr 20, 2006 09:23 PM
RTW DC2R
Aug 29, 2005 05:57 PM
zseeanz
Apr 5, 2004 07:48 AM
Islander
May 19, 2003 11:08 AM
