94 Honda Magna 750 won't start...
Old Sep 14, 2007 | 09:56 AM
downingracing's Avatar
Default 94 Honda Magna 750 won't start...
I've got a 94 Honda Magna 750 and it won't start. It had been sitting for 6-7 months and I got it running. I took it out for 5-6 miles and it was fine. Let it sit for another few months and the battery was dead. Put it on the charger (not disconnected) and charged the battery. Drained the tank and put new gas in it. Now it will crank like crazy but it won't start. Doesn't even sound like it wants to try to start... I haven't tried to pull a plug to see if I'm getting spark. Does anyone have anything I should check? Or a place to start? (Yes - the gas is turned on)
Matt
Old Sep 14, 2007 | 09:58 AM
.RJ's Avatar
.RJ
Default Re: 94 Honda Magna 750 won't start... (downingracing)
Plugs are fouled and/or carbs are gummed up.
Old Sep 14, 2007 | 11:24 AM
Default Re: 94 Honda Magna 750 won't start... (.RJ)
Any chance I damaged something when I charged the battery?
Old Sep 14, 2007 | 11:27 AM
.RJ's Avatar
.RJ
Probably not - if its cranking, its probably got enough voltage for spark. Check for voltage at the ignition coil(s) just to be sure, then test the plugs. You *might* get lucky and not have to clean the carbs - thats a V4, right?
Old Oct 13, 2009 | 01:02 PM
tisdale36's Avatar
New User
Did you get this bike running? If so what was the problem? Mine wont start either. Also if not, use seafoam in the tank to clean out carbs
Old Oct 13, 2009 | 03:29 PM
Jasper_db1's Avatar
Did you look @ the date on the thread?
Old Oct 27, 2022 | 09:05 PM
K-Strings's Avatar
Just recently found this thread. Not sure the date on it, my bad just clicked on it wanting to ask a question if anyone is still monitoring this post as of 10/25/22.
Haha ok so think I'm having a similar issue with my 94 magna 750, hoping to find out if the issue was resolved and how or maybe where to start with my own.
Ok while in the middle of a ride, 5th gear still accelerating after hitting a bump, so assuming possible short/bad wire. My bike backfired and immediately shut off, assuming fried the battery because will not hold charge now. But killed all power and what was a fairly new battery completely gone and won't hold charge. I could jump the bike which stayed running while connected to a running vehicle but as soon as it was either given any throttle at all or taken out of neutral it again shuts off and kills the battery completely. Far as I know I'm assuming it is bad stator/regulator. Just before spending the money on that was wanting to ask if it could possibly be something else. Thanks in advance.
Old Feb 29, 2024 | 03:30 PM
Moemotor759's Avatar
Check the rectifier. It'll frie ur bat when it go's bad
mcr1971
Jul 17, 2017 05:24 AM
Barb Riddell
Honda Ruckus and Scooters
Jul 12, 2017 08:44 PM
kgreenhaw
Nov 21, 2009 05:03 PM
beanoboy7
Honda Motorcycles
Aug 4, 2004 07:46 AM
low-tech assassin
Honda Motorcycles
Mar 2, 2003 01:02 AM
