throwing code 68 which I can not find on any check engine code list
I tuned my car a week ago and a couple days after while i'm driving and everything is fine then the car would bog/stutter one time and throw a code which is 68 and i have looked on multiple check engine code list but there is never a 68. if it throws the code and i turn my car off and on, the code is gone but the car will eventually bog/stutter again and throw the code again. I would like to know what the hell this code means and how do I fix it because it keeps doing it.
i even recorded the check engine light for people that might think i'm reading it wrong.
http://www.youtube.com/watch?v=gdAwFlGsjzA
please help, i'm afraid to drive my car because i'm paranoid that bad things will happen.
gsr motor:
usdm itr pistons
itr cams
hytech knockoff header
skunk2 intake manifold
70mm bbk tb
jdm itr 3'' intake
arp headstuds
obd1 p28 ecu
made 184whp and 130wtq sae corrected tuned on crome
gsr motor:
usdm itr pistons
itr cams
70mm bbk tb
jdm itr 3'' intake
arp headstuds
obd1 p28 ecu
any luck on finding out what it is? im having the same code on my single cam turbo Crx if i punch it from a dig that car falls on it face and has a fuel cut then that code comes out but if i ease into the gas and in top end its fined alittle help people
bringing it back from 07 huh, normally random codes are cause by a poor ecu chip or socket job, I'd check that first maybe try a different ecu
shabam
Jun 21, 2020 08:09 PM
shabam
Sep 15, 2007 06:33 PM
