throwing code 68 which I can not find on any check engine code list
Old Sep 14, 2007 | 09:45 AM
shabam's Avatar
Default throwing code 68 which I can not find on any check engine code list
I tuned my car a week ago and a couple days after while i'm driving and everything is fine then the car would bog/stutter one time and throw a code which is 68 and i have looked on multiple check engine code list but there is never a 68. if it throws the code and i turn my car off and on, the code is gone but the car will eventually bog/stutter again and throw the code again. I would like to know what the hell this code means and how do I fix it because it keeps doing it.
i even recorded the check engine light for people that might think i'm reading it wrong.
http://www.youtube.com/watch?v=gdAwFlGsjzA
please help, i'm afraid to drive my car because i'm paranoid that bad things will happen.
gsr motor:
usdm itr pistons
itr cams
hytech knockoff header
skunk2 intake manifold
70mm bbk tb
jdm itr 3'' intake
arp headstuds
obd1 p28 ecu
made 184whp and 130wtq sae corrected tuned on crome
Old Sep 14, 2007 | 10:37 AM
satitus's Avatar
Default Re: throwing code 68 which I can not find on any check engine code list (shabam)
That is really strange. I've never found a source to a code 68.
Only 58 and 48
https://honda-tech.com/zerothread/1901557
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Old Jun 19, 2020 | 07:47 AM
Jeremy64's Avatar
Only 58 and 48
16 Fuel injectors
23 Knock sensor
58 TDC sensor #2
67 Cat Converter
80 EGR Valve/Line
from knowledge learned Code 68 is like a boot loop for an i phone. Your ecu keeps trying to retune itself. There is an issue with the tune or the chips in the ecu itself
Old Jun 21, 2020 | 08:09 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
From what I’ve found 68 is a memory loss code. I’ve seen it on chipped ecus that had the 743hc373 chip not soldered in very well before.
shabam
Sep 13, 2011 01:41 PM
shabam
Sep 15, 2007 06:33 PM
djcue_530
Mar 15, 2007 08:53 AM
skontkanen
Nov 12, 2002 02:47 PM
