Looking to trade my freshly rebuilt 12:1 Comp LS/vtec for a stock longblock + $$
As stated;
Motor has only 3k miles on it. Its out of the car at the moment. Looking for TURBO D-SERIES swaps w/ cash depending on setup; any other b-series + cash (exc. built or ITR's/CTR's)
When it was rebuilt 3000 miles ago; it consisted of
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
NEW OEM LS water pump
B16A2 Pistons; STD bore
Fresh Hone
New OEM headgasket
Full-Race Dowel Pins
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
OEM valve cover with -8AN bung.
I'm located in jersey. Just wanna see whats out there.
Freshly rebuilt JDM b16 trans; trans is still apart at the moment; can re-assemble but prefer not to at the time cause im lazy. Comes with B-Series linkage w/ engery suspension bushings; brand new life time warrenty autozone axles.
Modified by pgpbubble at 8:20 PM 11/11/2007
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
Fresh Hone
New OEM headgasket
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">As stated;
Motor has only 3k miles on it. Its out of the car at the moment; Im just TW and would like to see if anyone has a stock LS/b20 longblock and some cash; would even consider a gsr longblock + cash or a b16 + cash.
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
OEM LS water pump
B16A Pistons; STD bore
Fresh Hone
New OEM headgasket
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
ITR valve cover
EARLS Endura Fittings for LS/vtec feed line
I'm located in jersey. Just wanna see whats out there; possibly lookingto go to the dark side.
</TD></TR></TABLE>pics would help you get rid of it and is the head milled?what year b16a pistons are they?
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
OEM LS water pump
Fresh Hone
New OEM headgasket
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
ITR valve cover
Head was never milled; just resurfaced. They are USDM 99-00 STD bore b16A2's.
I only have a camera phone at the moment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">Head was never milled; just resurfaced. They are USDM 99-00 STD bore b16A2's.
I only have a camera phone at the moment</TD></TR></TABLE>ok so they are pr3 pistons and is the head gasket a oem 3 layer?i'm not tring to be rude but i'm having trouble figuring out how it has 12:1 compression.
Every compression calculator comes out different; the most accurate one i've seen was the zeal autowerkz which is now down. It stated 11.97:1 compression
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
OEM LS water pump
Fresh Hone
<FONT SIZE="3">New OEM headgasket</FONT>
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
ITR valve cover
1995 LS block
ACL bearings
Polished Crank
Resurfaced Deck
ARP rod bolts
ITR oil pump
OEM LS water pump
Fresh Hone
LS timing belt
JDM b16 head
Blox IM
ITR throttle body
ITR valve cover
DOES NOT INCLUDE CLUTCH FLYWHEEL
Include $250 for Clutch and flywheel; Its an ACT HDPP;6Puck Unsprung Disc; OEM ITR Flywheel
how much on top a ls longblock..i have a ls in my ef hatch right now that i was gonna go turbo with...head was just resurface, so new OEM headgasket and ARP headstud, 125,xxx on the motor....it has a ACT lite flywheel and stage 2 clutch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 »</TD></TR><TR><TD CLASS="quote">ok so they are pr3 pistons</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpbubble »</TD></TR><TR><TD CLASS="quote">thanks man;
danronian has the head from this shortblock
Did. Sold to someone an a local forum with a block I had... Was a very mint looking head.
</TD></TR></TABLE>Did. Sold to someone an a local forum with a block I had... Was a very mint looking head.
