92-95 w/o factory sway bars, ST sway bar installation probs, please help!
I purchased the ST sway bar kit for my 93 EG which does not have stock Front or Rear sway bars. I have a problem with the rear sway bar setup.
I followed the instructions and rotated the strut assembly 180 degrees so the fixed/dead nut will be facing the other way, but I noticed I don't see where I can bolt the bushings to the chassis. The instructions say something about drilling a hole, but the only place I see where the two bushings can mount up ends is on the gas tank, and for sure I aint' bout to drill my gas tank.
Does anyone have suggestions or pictures to show me their ST sway installs on a non OEM sway existent EG hatch?
If you look close enough, there's 2 little holes in the area where you mount the LCA's to the sub frame. That's where the D brackets should be. I prolly can take some pics this Tuesday.
That would be superb if you can take some pix for me. Cuz i just absolutely can't find any mounting pts...
sup jeff
the CEL we got while running my car last time was from the Vtec ground being loose. hehe
JMelt4
18
Apr 30, 2007 07:43 PM
katb16vo
22
Mar 25, 2004 03:29 PM
