crx turbo question
so i have a crx with an eg radiator for my setup, my radiator is way tall, my hood wont close and the only way that it will is if i force it on to a serious gangster lean, any suggestions??
Thanks,
Tokyo
Thanks,
Tokyo
I'm running a half-sized radiator in my ef as well. How i dealt with this problem was by trimming the crossmember and the back of the frame that sits directly in front of it, that did the trick a little bit, but in order for me to have little to no lean i cut the webbing off the hood.
Worked well for me. But if cutting stuff up isn't your style then you will need to buy an aftermarket traction bar or hood.
kool thanks alot....and yea i dont mind triming off the webbing for the hood.......so then i would just cut out like a half rectangle that'll fit my radiator?? and then how would it sit?? would the top radiator mount be wat'll be holding it?
88 rex
Sep 8, 2005 04:37 PM
BoostdRex
34
Aug 15, 2005 08:15 AM
