Steering column slipping out when tightening bolt at bottom near firewall (92-95) Help!!
I can not figure out why the steering column keeps slipping out of the female end at the firewall. I had my brother tighten the screw through the column as I pushed the column toward the firewall and still the thread column backed out pretty far
Should I tighten down the 2 nuts that hold the column at the bracket? Angle the neck of the column at the firewall?
Thanks for any advice on this.
Should I tighten down the 2 nuts that hold the column at the bracket? Angle the neck of the column at the firewall?Thanks for any advice on this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">I wish I could help you, but I'm not exactly sure what the problem is. The way you described it left me confused.</TD></TR></TABLE>
I am tightening Bolt #9. As I tighten #9, #1 begins to back out of #4. I have pics of before removing the column and the threads are sticking out maybe 1/16". By the time I tighten the bolt the threads have backed out 3/4".
Should I tighten bracket #2 down completely? There are alos 2 nuts holding the column up to the chasis which appear to be #10 in the diagram. They go directly above where the nut is pictured.
Thanks again for any help with this.
I think your not getting the splines deep enough into the colume before you [put the bolt in. Also tighten the upper end a bit, up by the wheel.
I've changed a couple of steering racks and never had the problem you discribe.
if you've stripped the threads, I have a spare u-joint.....where did I put that damn thing?
You know there is two bolts on the u joint right? Second clamp bolt attaches the the steering rack.
Once I tightened the column up top and at the U joint it held in place fine
Nice and snug
Nice and snug
hatcht9x
Jun 29, 2008 01:45 AM
theeogflip
Mar 23, 2008 10:45 PM
hondacivichatch
Mar 9, 2006 03:08 PM
