Failed smog need help
Old Sep 13, 2007 | 08:49 PM
TheTealHatch's Avatar
Default Failed smog need help
I got my car smogged and I didn't pass. I failed HC(ppm) at 15mph. I went over 7 points. The max was 92 and I had a 99. What could be the problem that could cause this? Need help ASAP
Old Sep 13, 2007 | 09:17 PM
ek-g6's Avatar
Default Re: Failed smog need help (TheTealHatch)
could be that you need change oil, before you go smog, because if your oil is going bad then, it might have seeped into combustion chamber and the exhaust gases are carrying it out with other hc that already in there. that might be the problem. it worked for me and its just a thought for you.
Old Sep 14, 2007 | 01:07 AM
Default Re: Failed smog need help (ek-g6)
Yeah I did an oil change before I got it smogged
Old Sep 14, 2007 | 05:13 PM
bump
come on guys i need some help. State Ref coming up in a few days
Old Sep 15, 2007 | 10:29 AM
silentbeatz's Avatar
7 HC is little to fail by. you can change the spark plugs and it should go down or lower your timing 1 degree. run 91 gas.
Old Sep 15, 2007 | 01:31 PM
ddd4114's Avatar
Default Re: (silentbeatz)
We can help you better if you post your entire emissions results.
How are your plugs/wires/cap/rotor? Have you checked your o2 sensor?
jdmcivic2fast
Oct 21, 2011 06:41 PM
danrsx
Aug 31, 2010 12:46 PM
theslugbug
Jan 14, 2008 06:28 PM
IshbOO
Oct 17, 2005 05:56 PM
Curtisbeef
Dec 6, 2004 01:06 PM
