help! skunk2 IM install
Old Jun 16, 2002 | 08:58 PM
boot machine 5000's Avatar
Default help! skunk2 IM install
i have a b18c in my ek and running on a si ecu. well i finished putting the manifold on and when i started it up he cars idle jumps around. its idles at 1000 and 2000rpm jumping back and forth. why does it do this? also anyone have a pic of how the t-fittings suppose to be connected. thanks.
[Modified by Alvin, 7:12 AM 6/17/2002]
Old Jun 17, 2002 | 12:34 AM
PYITR821's Avatar
Default Re: help! skunk2 IM install (Alvin)
Check this out!
<U> http://tiiite.b16a.com/tech/sk2manifold/ </U>
Old Jun 17, 2002 | 01:03 AM
Kamin's Avatar
Default Re: help! skunk2 IM install (JUNtypeR)
and if that dosent work you may have a vacume leak
spray some carb cleaner around the intake manifold (where it meets the head). if the rpm's drop in a certan area you have a leak.
Old Jun 17, 2002 | 03:58 AM
GruvyTune's Avatar
New User
Default Re: help! skunk2 IM install (KAMiN)
i had that when i first installed mine, I had to lower my fuel pressure a bit as it tended to run a bit rich from what I remember, not sure why.
Old Jun 17, 2002 | 11:05 AM
Default Re: help! skunk2 IM install (GruvyTune)
thanks! i just got a new gasket, hopefully this will fix it.
daleSol
Feb 13, 2013 09:08 AM
jetspeedz
Aug 17, 2009 08:22 AM
98TypeSH
Oct 4, 2004 09:05 AM
DaiJekBok
Apr 28, 2003 06:39 PM
boot machine 5000
Jun 17, 2002 02:30 PM
