Car won't start????
Old Sep 13, 2007 | 06:52 PM
Mr. TopFuel's Avatar
Default Car won't start????
Was curious to ask you guys on what you think what could be the reason my car finally died.
Specs on the motor:
Motor:B18c5 stock head and block.All ITR Internals.Miles 227,+++"yes all original miles"Stock intake and comptech header. VAFC controller
Tranny:JDM ITR Tranny 4.78 with cusco LSD
Ok the story:
I was driving home from work when i was coming to a stop light, turning right. I down shifted to 3rd and i let go of the clutch and give it gas and the car jerks very little then dies, without any noise. Before it died, it never gave me any warning (no check engine light/Car ran and sounded fine)
As i came to a safe area to stop, i turned the key and it barely catched and ran for a .1 sec and shut right off. Then i try it again and it sounds like it wants to start but no grab. I took off the starter and had it tested and it's fine. I checked the spark plugs and they smell and look ok. I changed my timing belt and water pump not to long ago as well.
I recently just changed the oil and spark plugs.
You guys think it could be my distributor? It's never been changed.
Old Sep 13, 2007 | 07:18 PM
Can anyone give me some help.
Old Sep 13, 2007 | 07:26 PM
get RIGHT's Avatar
Default Re: (Mr. TopFuel)
I'm thinking it sounds clutch/flywheel related. Like maybe your flywheel disentegrated on you. Just a stab in the dark though.
Old Sep 13, 2007 | 08:48 PM
Default Re: (get RIGHT)
Thanks. I had some of my friends say it might be my distributor or relay or fuel related.
Old Sep 13, 2007 | 09:16 PM
highroller54's Avatar
find out what you are loosing spark, fuel pressure, injector pulse or a combo of. Untill you know what is gone you will just be guessing, but sounds like coil or igniter to me
Old Sep 13, 2007 | 09:46 PM
cwjaydemitr's Avatar
i second the clutch related problem.
Old Sep 13, 2007 | 09:56 PM
Default Re: (cwjaydemitr)
I checked the spark plugs while waiting for the tow truck..They looked fine and wires are ok. I just changed them 3weeks ago along with the oil and filter.
But the clutch still feels the same. The flywheel is a Fidanza. I'll have to look into that.
Old Sep 13, 2007 | 10:13 PM
CW-ITR's Avatar
I'm leaning on bad ignition coil or bad igniter.
Old Sep 14, 2007 | 11:11 AM
Default Re: (CW-ITR)
Does anyone have the Manuel online on where the ignition coil is? or ingniter?
Or does anyone else have some thoughts on what it could be?
Old Sep 14, 2007 | 11:14 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. TopFuel &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone have the Manuel online on where the ignition coil is? or ingniter?
Or does anyone else have some thoughts on what it could be?</TD></TR></TABLE>
It's in the dizzy. There are a couple main components...
Cap, rotor, Igniter. Those 3 you can replace...
The cam sensor is the one you can't. You'd need a whole new dizzy if it were that.
Old Sep 14, 2007 | 11:23 AM
Default Re: (Dave_B)
What does the igniter look like? Sorry if i sound like a newb.
Cause i replaced the rotor and cap about 4months ago.
Old Sep 14, 2007 | 11:33 AM
tartje's Avatar
was there any fuel on the plugs when you pulled them?
Old Sep 14, 2007 | 12:02 PM
Default Re: (tartje)
No, the plugs had no gas on them..I even smelt then and nothing..They looked normal.
Old Sep 14, 2007 | 12:15 PM
tartje's Avatar
as i originally thought, i bet its a fuel problem
Old Sep 14, 2007 | 12:20 PM
You think the fuel filter is bad? Or something else
Old Sep 14, 2007 | 03:34 PM
N1civicSi's Avatar
should there be fuel on the plugs???
Old Sep 14, 2007 | 06:16 PM
00TypeR1071's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW-ITR &raquo;</TD></TR><TR><TD CLASS="quote">I'm leaning on bad ignition coil or bad igniter. </TD></TR></TABLE>
It's probably the ignition coil. I had the same problem in my old Civic.
Old Sep 14, 2007 | 06:30 PM
Default Re: (00TypeR1071)
Well i just picked up a distributor, so will see if its that.
Old Sep 14, 2007 | 08:16 PM
Just installed the new distributor and the car started right up.
Thanks to all for your help and input
Old Sep 14, 2007 | 08:19 PM
JjuuN R's Avatar
Nice!!
Old Sep 15, 2007 | 06:22 AM
Dave_B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. TopFuel &raquo;</TD></TR><TR><TD CLASS="quote">Just installed the new distributor and the car started right up.
Thanks to all for your help and input </TD></TR></TABLE>
If you didn't touch the ignitor in your diagnosis and you had changed cap/rotor it was either the Ignitor or the Cam sensor.
Glad to hear it worked out.
Old Sep 15, 2007 | 06:32 AM
JjuuN R's Avatar
Morning Dave.
Old Sep 15, 2007 | 06:34 AM
Dave_B's Avatar
Top of the morning Cory!!!
&lt;---- stuck at work imaging a PC and replacing a failed HD in one of our servers... Then gotta rebuild the RAID array.
But.... Party at 3.
Old Sep 15, 2007 | 06:40 AM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">But.... Party at 3. </TD></TR></TABLE>
Nice.
Old Sep 15, 2007 | 07:00 AM
Dave-ROR's Avatar
Glad to hear it worked out.</TD></TR></TABLE>
Or since he never told us if he inspected the dist, the rotor screw may have backed out.
