skunk2 cam gears installed, car runs then dies
so a mech i know installed some skunk2 cam gears in, he set the them at 0/0. so i went to start the car, it starts, then dies a few seconds later...i looked on the skunk2 site, it says 1.5/2.0...i just want to get it running to get it to a dyno...i have a vafc but not installed yet....are they hard to adjust? any tips will be help full...thanks..
If the cam timing is set to stock, it should run just fine. Have you verified that the cam timing is set to stock? Is the timing belt installed correctly?
Not unless the cam gears were machined incorrectly. If they were at 0 on the intake and exhaust, the car should run fine. I'm betting the install a fubar.
Modified by 117 at 6:07 AM 9/14/2007
94IntegraLs04
Feb 27, 2005 12:49 PM
CNUKPUP
Oct 15, 2001 01:17 PM
