Engine harness question
Old Sep 13, 2007 | 02:56 PM
duckmanEG's Avatar
Sexy Cheese Cake
Default Engine harness question
Well i am having a couple codes being thrown on my crx i just got running. Mini me, obd1.
Codes
4 CKP - crank position sensor
6 ECT - water temperature sensor
10 IAT - intake air temperature sensor
I could have sworn i pulled an engine harness of a 88 si. Yeah yeah i know not smart. Well i had switch the plugs so it can work with my 91. Now after looking at the wires that trying to figure what is what. I think i pick up a HF harness. Because i have all the colors of the HF one. On my old clip i had for the SI chassis side i have a black/yellow and blue wire still open. So can i make this work or no.
Connector 313 Si onleft tower 8pin
1)brn injec#1
2)red injec#2
3)blu fast idle contrl solenoid valve (SI only)
4)blk/yel 12v+ switched
5)yel injec#4
6)lt blu injec#3
7)yel/blk 12v+ swtiched (injectors)
8)blu/yel IAC valve
Connector 313 HF on left tower 8 pin
1)wht ignition ouput signal (to igniter)
2)blu/yel IAC valve
3)yel/blk 12v+ switched (injectors)
4)brn injec#1
5)yel injec#4
6)yel egr valve lift sensor ref. voltage. (not used)
7)red inj#2
8)lt blu inj#3
This was provided by 1 Fly SI. Also give me other information that led to me finding out my alternator problems and ELD. Which ever idiots put the car together before had them switch on the ecu pins. Stupid people. Which leads me to think since the car is running decent (limp mode) that is probably more then the engine harness.
Old Sep 14, 2007 | 08:52 AM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: Engine harness question (duckmanEG)
anybody?
Old Sep 14, 2007 | 04:27 PM
Boosted Chemist's Avatar
bookmarked for later, too stoned to think right now
Old Sep 15, 2007 | 06:59 AM
reynardmauricio's Avatar
Default Re:
so, ur car is a 91 Si? why didn't u use ur old harness? then u just run vtec wires and rewire ur dizzy.
Old Sep 15, 2007 | 07:31 AM
duckmanEG's Avatar
Sexy Cheese Cake
Default Re: Re: (reynardmauricio)
Yes a 91 crx si
Because i pick the car up as a roller and it was missing the engine harness.
It has the rywire conversion harness and i did my own dizzy conversion.
Old Sep 15, 2007 | 09:31 AM
Default Re: Re: (duckmanEG)
Crank ps, i think would be in the dissy wiring, (how did you convert?)
IAT is straitgh forward, Check the sensor for ohms (1-4ohms) and 5 volt running
Old Sep 15, 2007 | 11:08 AM
Default Re: Re: (Boosted Chemist)
like boosted chemist said, ect and iat are pretty much straight forward and ckp is most likely from ur dizzy wiring. btw, what dizzy are u using and on what head?
Old Sep 15, 2007 | 01:57 PM
duckmanEG's Avatar
Sexy Cheese Cake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">Crank ps, i think would be in the dissy wiring, (how did you convert?)</TD></TR></TABLE>
My own conversion harness, using the clips from an ef to the clips on an eg just depin and repin with some extra wire in between.
Im going to check voltage right now.
Old Sep 15, 2007 | 01:58 PM
duckmanEG's Avatar
Sexy Cheese Cake
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reynardmauricio &raquo;</TD></TR><TR><TD CLASS="quote">btw, what dizzy are u using and on what head?</TD></TR></TABLE>
A z6 dizzy and head.
Old Sep 15, 2007 | 02:51 PM
duckmanEG's Avatar
Sexy Cheese Cake
Well i got it figured out. The red/yellow and red/white where on the wrong clip on the pass side. Then the green/yellow and green/blue where also on the wrong clip. Oddly enough there were completely switch around. So i swap them in there right place and boom car starts up and no more codes, no more limp mode.
I hate working other peoples failed projects. Probably why it failed them. Got sick of trying to figure it out, haha.
Thanks for everyones help.
8VEYBEYB
Sep 25, 2009 09:40 AM
Aquafina
Dec 2, 2007 11:47 PM
dkrex001
Dec 2, 2007 09:49 PM
lemongreenhatch
10
Dec 12, 2004 10:11 PM
gutted
Nov 3, 2004 08:35 AM
