Need help fast... Quick Suspension question??????????????????????
Old Sep 13, 2007 | 02:47 PM
hondacivic90zc's Avatar
Default Need help fast... Quick Suspension question??????????????????????
Hey i need an answer asap. Will 1988 crx dx rear lower control arms fit a 1990 civic dx? The reason is that i have a wrecked 1988 crx dx with kyb's that are still good and my 1990 civic dx has cut springs and stock struts so i am wanting to switch them out. I just got the wheels off of both of the cars and i found that the 1990 civic has what looks like cast iron rear lower control arms and the crx has stamped steel ones that are wider. They both use different shock mounts on the arms so i just want to switch the whole arms.
Now will i run into any camber/toe problems changing these or should i be find because i figure the geometry of both cars is the same to the best of my knowledge.
Quick help would be appreciated.
Old Sep 13, 2007 | 04:23 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
you will still need a wheel alignment just from everything resettling, but they should be the same exact pieces.
Old Sep 13, 2007 | 04:37 PM
Default Re: (ComeOnKip)
thanks yeah i just went ahead and put them on. They fit perfectly and the wheels are pretty good even without an alignment but thank you for the response.
primetimedx
11
May 24, 2006 09:37 PM
cbp_crx
Apr 19, 2006 07:41 PM
ep3boy
Jun 14, 2005 07:55 AM
Fu_kJDM
Mar 27, 2005 11:40 PM
I_love_my_Crx
Apr 2, 2003 10:07 AM
