HELP!! Gas mileage???
Old Sep 13, 2007 | 02:47 PM
greenej8's Avatar
Default HELP!! Gas mileage???
D16y8 with all basic bolt-ons and Phearable.net OBD=1 conversion. i'm getting like 200-220 miles per tank. That's only like 21 mpg! Anyone else having this problem or know of ANYTHING that might be causing this?? Any help would be great!!!
Old Sep 13, 2007 | 05:25 PM
kadidle's Avatar
Default Re: HELP!! Gas mileage??? (greenej8)
spark plugs, distributor cap, distributor rotor, fuel injectors, tps(throttle position sensor) sensor, o2 sensor. depends how many miles on motor they all could be worn and all be taking away the gas milage.
Old Sep 13, 2007 | 08:00 PM
greenej8's Avatar
Default Re: HELP!! Gas mileage??? (kadidle)
Thanks for the suggestions but all have already been checked and serviced or replaced. I did the OBD-1 conversion because my secondary o2 sensor went out and it was going to be like 300 bucks and the conversion was only like $180 chipped p28 ecu, harness and all. Still have no clue why it could be killing my tank like this......
Old Sep 13, 2007 | 09:42 PM
ToeJam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenej8 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the suggestions but all have already been checked and serviced or replaced. I did the OBD-1 conversion because my secondary o2 sensor went out and it was going to be like 300 bucks and the conversion was only like $180 chipped p28 ecu, harness and all. Still have no clue why it could be killing my tank like this......</TD></TR></TABLE>
what chip is in it?
Old Sep 14, 2007 | 09:01 PM
greenej8's Avatar
Default Re: HELP!! Gas mileage??? (ToeJam)
It's just a basemap Phearable tune specifically for the mods to my motor. Should run fine but who know's why... Just found out my alternator is only putting out 30 amps when it should be like 65+ so now i've gotta replace that.
Old Sep 15, 2007 | 08:28 AM
GreenGSR's Avatar
had the same type of problem with my gsr. was getting 20-22 mpg. I had a "mugen" chip that was just dumping in fuel. apparently all sensors were disabled. I replaced the chip, had a base map put on and now get 29-32. quite a difference when gas is $3/gal
Old Sep 16, 2007 | 09:35 PM
greenej8's Avatar
Default Re: HELP!! Gas mileage??? (GreenGSR)
Yeah it sucks spending all this cash dumping gas in what is considered a "gas saver"!! It's also really hard to find anyone good to tune where i'm located.
bboixtc
Dec 17, 2007 06:02 PM
greenej8
18
Oct 29, 2007 09:26 AM
Mr.Luder
Aug 11, 2007 04:13 PM
sickofitall1113
Nov 10, 2006 12:41 PM
DC2uNer
Jan 15, 2004 09:58 PM
