Mini Me Swap Question
Old Sep 13, 2007 | 11:36 AM
ESP.net's Avatar
Default Mini Me Swap Question
I was reading the thread below and have 2 questions. Didn't recommend replacing oil pump with a vtec one...so I am guessing there isn't much difference in flow between the two? Also will the Crx Si intake manifold work (perform well) on Z6 vtec head?
Old Sep 13, 2007 | 11:59 AM
dr_latino999's Avatar
Default Re: Mini Me Swap Question (ESP.net)
No difference, between the A6 and Z6 oiling capacities, the Y8 had less, and yes the A6 intake manifold would work fine.
Old Sep 13, 2007 | 12:04 PM
ESP.net's Avatar
Default Re: Mini Me Swap Question (dr_latino999)
Thanks got another question didnt see anything about using Z6 head bolts not necessary? Non vtec D head bolts work fine?
Old Sep 13, 2007 | 01:34 PM
If you are using a Z6 head, no change is needed. If you are using a Y8 head, two bolts/studs need to be changed.
Old Sep 13, 2007 | 02:11 PM
jdm_titan's Avatar
thanks this helped me out too
neroren
Mar 16, 2009 04:26 PM
civictypenos
Jul 28, 2004 10:36 AM
crashtest Sonny
Sep 1, 2003 12:48 PM
