5th gen Innovative Motor Mounts
Old Sep 13, 2007 | 08:42 AM
Mr.Luder's Avatar
Default 5th gen Innovative Motor Mounts
I have a 00 Prelude Base
Has anyone used them yet? How are they? Any bad vibration?
Also, I heard it will eliminate the oem front motor mount. Is that true?
Last, can someone link me if the above statement is true. My thread on the block for the front mount has some how stripped. I'd rather just replace the three so I dont have to rethread it. Lemme know guys.
p.s. is search not working? I swore there was a topic on innovative mounts but it keeps telling me no results found
Old Sep 13, 2007 | 08:17 PM
Mr.Luder's Avatar
Default Re: 5th gen Innovative Motor Mounts (Mr.Luder)
BUMP
Old Sep 13, 2007 | 09:19 PM
Slick_LudE's Avatar
keep in mind when you get these after-market mounts, the urethane inserts are USUALLY stiffer as these are usually used for higher horse power engines. Their goal is to reduce/eliminate torque movement. The down side is that the engine vibration gets transfers to the chassis which will create more vibration in the car.
If you want something that will be smooth you will want the OEM replacement.
Old Sep 13, 2007 | 09:22 PM
Slick_LudE's Avatar
Default Re: 5th gen Innovative Motor Mounts (Slick_LudE)
Oh and I dont know about the fact that it will eliminate the front mount. Innovative makes their own front mount and their "motor mount set" includes the front, front driver and the rear. It doesn't include the tranny mount if that is what you are referring to.
Old Sep 13, 2007 | 09:34 PM
Mr.Luder's Avatar
ok...let me clear some things up
first, i want aftermarket mounts not inserts.
second, the holes on the block for the front motor mount bolts are stripped on my car. So this is why I am looking for a way to eliminate the front.
Third, I'm not worried about vibration...but from what i understand the innovative mounts cause minimal vibration with minimal wheel hop.
fourth, they sell it with the tranny mount left mount and rear mount, NO the front mounts. so yes the tranny mount is included
Old Sep 13, 2007 | 10:37 PM
AznBlueBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">
fourth, they sell it with the tranny mount left mount and rear mount, NO the front mounts. so yes the tranny mount is included</TD></TR></TABLE>
you are right
im using the es inserts right now and i have a lot of vibrations. im going to go with the innovative mounts because theres little to no vibrations from what i'v heard and reduces wheel hop even more.
Old Sep 14, 2007 | 01:58 AM
Mr.Luder's Avatar
Default Re: 5th gen Innovative Motor Mounts (AznBlueBoy)
you know where i can order some too?
Old Sep 14, 2007 | 02:48 PM
AznBlueBoy's Avatar
project dc2 and hybrid performance sells them.
Old Nov 6, 2007 | 07:53 PM
Mr.Luder's Avatar
Bump for 5th gen Review on Innovative Mounts or I'll give the review when my order comes in!
Old Nov 6, 2007 | 08:58 PM
Rosko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">you know where i can order some too?</TD></TR></TABLE>
just call them directly. thats what I did for my 4th gen mounts. same price as everyone else as far as I could tell.
Old Nov 7, 2007 | 07:11 AM
Mr.Luder's Avatar
Default Re: 5th gen Innovative Motor Mounts (Rosko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rosko &raquo;</TD></TR><TR><TD CLASS="quote">
just call them directly. thats what I did for my 4th gen mounts. same price as everyone else as far as I could tell.</TD></TR></TABLE>already ordered some just wondering
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Luder &raquo;</TD></TR><TR><TD CLASS="quote">Bump for 5th gen Review on Innovative Mounts or I'll give the review when my order comes in!</TD></TR></TABLE>
Old Jun 30, 2008 | 06:55 PM
wle05's Avatar
any updates on how well the mounts are? how much vibration?
Old Jun 30, 2008 | 11:18 PM
Mr.Luder's Avatar
Default Re: 5th gen Innovative Motor Mounts (wle05)
oops, forgot to update.
well, i ordered them and got them in. the vibration is really light while idling but when the a/c is turned on there is a lot of vibration. I'm not to sure how the inserts are but with these mounts with the a/c on you can feel vibration through out the whole car. Things started to rattle so I removed the rear mount and left the two sides. Vibration is now gone. All in all, they are some excellent mounts if you want to eliminate the front mount and reduce wheel hop. But if your expecting little to no vibration, than they are not for you. i did it because the bolts on my front mount that mount to the engine block broke and i didn't feel like drilling them out. now i have 1 out of 3 holes fixed so i'm just using 1 at the moment.
Old Jul 1, 2008 | 04:35 AM
G2IntegraGS's Avatar
Did you let them breakmin? Mine vibrated like a **** until they broke in.
BigMike2001
Sep 11, 2013 12:58 AM
#1rudebwoy
Oct 6, 2010 08:12 AM
lildrgn2.0
Jul 20, 2005 01:48 PM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Muckman
Aug 28, 2002 12:18 AM
