Are Rocket M24X too large for stock c/r JDM B16???
Old Sep 13, 2007 | 06:45 AM
klungemonger's Avatar
Default Are Rocket M24X too large for stock c/r JDM B16???
I was thinking of getting a set of these cams but are they just too large for an OBD1 JDM B16? I believe the stock compression is 10.4, if that is too low would a set of CTR's get me in the range of these cams? Thanks for your expert advice!
Old Sep 13, 2007 | 07:12 AM
American.Graffiti's Avatar
Default Re: Are Rocket M24X too large for stock c/r JDM B16??? (klungemonger)
yes.
Old Sep 13, 2007 | 07:53 AM
black jdm type R's Avatar
for that oem comp it's too much you need at least 13 to 1 of comp
Old Sep 13, 2007 | 08:25 AM
Furyof4's Avatar
Default Re: (black jdm type R)
hahaha....yes a tad too large
Old Sep 13, 2007 | 09:35 AM
mar778c's Avatar
Community Builder
Community Influencer
It would not be a optimal selection for that motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black jdm type R &raquo;</TD></TR><TR><TD CLASS="quote">for that oem comp it's too much you need at least 13 to 1 of comp </TD></TR></TABLE>
Wrong, comp is a tertiary effect. 13:1 won't make much if any difference. The problem is the 1.6 simply does not have the flow capacity to make much power below 7.5 K with that cam.
Old Sep 13, 2007 | 10:30 AM
Aquafina's Avatar
Yep.
Try M21X.
https://honda-tech.com/zerothread?id=2090218
Old Sep 13, 2007 | 11:49 AM
alterdcreations's Avatar
Default Re: Are Rocket M24X too large for stock c/r JDM B16??? (Aquafina)
or rev that 1.6 to 10,000 plus
Old Sep 13, 2007 | 11:53 AM
mar778c's Avatar
Community Builder
Default Re: Are Rocket M24X too large for stock c/r JDM B16??? (alterdcreations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">or rev that 1.6 to 10,000 plus</TD></TR></TABLE>
Yeap, but that just makes sh*tty power, lol.
I have a friend with s2s3s in a 1.6. It's pretty bad.
DjBij099
Apr 8, 2008 05:47 PM
92HB_HB
Jan 15, 2008 04:33 AM
jdmb1697ek
16
Mar 8, 2005 04:21 AM
anothersickhatch
Aug 14, 2004 06:58 AM
