DIY Tricks to Make a Sohc Quick
Old Sep 12, 2007 | 09:48 PM
SohcVtaak's Avatar
Default DIY Tricks to Make a Sohc Quick
I've been looking for any tricks what-so-ever to make a single cam d16y7 a bit quicker.
I've done the dizzy adjustment but that can't be the only thing can it?
Modified by SohcVtaak at 11:00 PM 9/12/2007
Old Sep 12, 2007 | 10:02 PM
rivaladore's Avatar
Default Re: DIY Tricks to Make a Sohc Quick (SohcVtaak)
an EX tranny will bolt up no problem, the shorter gearded trans will give you better acceleration.............everyone else will tell you don't waste your money.... boost it....or do a mini-me.......search the FAQ's at the top for info on the mini-me if you're interested......
nit pickers might suggest.....weight reduction(flammers- "drop a couple pounds...yea you not your car")......remove ps/ac...underdrive pulleys.....lighter flywheel, tune up/tune....etc..........i say save for a swap and/or boost
Don't respond to this thread just let it die, no one on here really appreciates these questions
Old Sep 12, 2007 | 10:32 PM
creeper ej's Avatar
Yeah, the EX tranny swap, along with a lighter flywheel (not tooo light.. ask the guy at the shop for guidance) and a slight (stage1) clutch upgrade will make you dig this car all over again. I threw in a short shifter with mine while I was down there and I'm loving the setup thus far. Getting ready to do the mini me head swap.. everything I've read says it's a good cheap way to bump it up. Cams are something you'll want to look at as well. Maybe some head work before you put it in.
For your situation, I'd look at d-series.org also. There are a lot of people on honda-tech that offer really helpful advice, but most people are into what you can do with a b, k or h-series engine swap (which you shouldn't rule out, depending on your cash flow situation/hp and torque goals, etc)
I can appreciate your situation because I'm in the same boat. Good luck, bro.
Old Sep 12, 2007 | 10:33 PM
Doostur's Avatar
Make it quick... add another SOHC
Old Sep 13, 2007 | 12:32 AM
instrument's Avatar
add a turbo.
you can fashion one out of a sea shell and a used boat propeller.
any DIY changes will be minimal...seriously...
Old Sep 13, 2007 | 01:35 AM
quicksilver1689's Avatar
i ♥ snails
maybe a small t3 tubro, cast mani, ebay fmic, dsm 450's, and a basemap on a chipped ecu is up your alley?
Old Sep 13, 2007 | 04:01 AM
sohc_boy's Avatar
Default Re: (quicksilver1689)
its pretty easy to build a mild n/a setup or go the f/i route, really it all depends on what you want. either way that ex tranny swap is the 1st thing i'd do. as mentioned earlier u can goto d-series.org and search there are quite a few people who have y7 builds going on myself included.
Old Sep 13, 2007 | 05:09 AM
EK_kidd's Avatar
Default Re: (sohc_boy)
Wat I did was tighten the slack on my trottle cable.. It WON'T make u faster just a lil extra jump off the line.. And adjust your timing and oil change spark plugs a lot of lil things can make a big difference
Old Sep 13, 2007 | 05:48 AM
big-cat's Avatar
screw the head swap, you have to either swap tranny or boost or both
Old Sep 13, 2007 | 05:51 AM
03akkord5spd's Avatar
ex tranny, y8 intake mani, ebay header. past that, any extra money should be put into suspension, IMO...
Old Sep 13, 2007 | 05:57 AM
big-cat's Avatar
the y8 intake mani isnt going to do ****(i already did it, and did not do a damn thing) along with the egay header doesnt do anything.
Old Sep 13, 2007 | 06:23 AM
ennah's Avatar
Default Re: (big-cat)
<quote>the y8 intake mani isnt going to do ****(i already did it, and did not do a damn thing) along with the egay header doesnt do anything.</quote>
The y8 intake manifold does make a difference, your getting more power out of your intake manifold because it is larger
Old Sep 13, 2007 | 06:24 AM
SohcVtaak's Avatar
I have the y8 manifold sitting in my garage but I need to find a sensor that only came with the ex. Already did suspension work, slammed 4 inches all around on Tein S techs.
Old Sep 13, 2007 | 06:27 AM
SohcVtaak's Avatar
Default Re: (EK_kidd)
Can you see the difference in the gear length between the y8 and 7?
Old Sep 13, 2007 | 06:28 AM
AE_Racer's Avatar
Default Re: (SohcVtaak)
"slammed" isnt suspension work.....
Old Sep 13, 2007 | 06:37 AM
crazyguy's Avatar
weight reduction.... swap the ex tranny wont make your car go any faster...header or exhaust wont make your car go any faster without proper engine tuned.. boost it ..is the only way to gain power.
i had a z6 with ex manual tranny..header to exhaust..intake.....it is still slow
Old Sep 13, 2007 | 06:38 AM
ennah's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcVtaak &raquo;</TD></TR><TR><TD CLASS="quote">I have the y8 manifold sitting in my garage but I need to find a sensor that only came with the ex. Already did suspension work, slammed 4 inches all around on Tein S techs.
Yeah it is a difference because if im not mistaken a y7 has longer gears than a y8, a y7 tranny would be good for boost. A y8 tranny has nice short gears
Old Sep 13, 2007 | 06:59 AM
SohcVtaak's Avatar
Default Re: DIY Tricks to Make a Sohc Quick (crazyguy)
Last time I checked lowering your car dramaticly, a strutbar in the front and one in the back was plenty to keep your tires on the floor.
Old Sep 13, 2007 | 07:05 AM
AE_Racer's Avatar
Lowering your car dramatically without sufficient shocks makes it pointless.
Old Sep 13, 2007 | 07:08 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SohcVtaak &raquo;</TD></TR><TR><TD CLASS="quote">Last time I checked lowering your car dramaticly, a strutbar in the front and one in the back was plenty to keep your tires on the floor.</TD></TR></TABLE>
yeah it is for handling..
u were asking how to make your car go faster..u were not asking how to make your car handle better
and also how much are u looking to spend on this "make a car go quick" ?
Old Sep 13, 2007 | 07:25 AM
Lasty K's Avatar
From reading and all, I'd say...
y8 intake manifold
then boost.
That's the "quick" way to make power with the D series.
Old Sep 13, 2007 | 07:34 AM
pork's Avatar
yeah boost is pretty much the only thing that will help a d series, otherwise you'll be wasting your money (and lots of it) to build a quick NA d series car.
Old Sep 13, 2007 | 07:40 AM
97exd16's Avatar
Default Re:
ex tranny, y8 intake manifold, ebay header and AEM short ram. that'll do donkey. that'll do.
Old Sep 13, 2007 | 07:47 AM
Syndacate's Avatar
Default Re: Re: (97exd16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97exd16 &raquo;</TD></TR><TR><TD CLASS="quote">ex tranny, y8 intake manifold, ebay header and AEM short ram. that'll do donkey. that'll do.</TD></TR></TABLE>
Go with an EX trans, and save your money about the other stuff. Just get a decent header and a more aggressive camshaft - chip an OBD-I ECU and get it tuned. Other than that, it's not really gonna be nothing quick w/o turbo or a serious NA build.
Old Sep 13, 2007 | 08:07 AM
95ProjectEJ1's Avatar
Default Re: Re: (Syndacate)
Or by spending all that money he would have put into the D16 and purchase a B18b1
