Repairing snapped threaded 8mm studs(?) in firewall? Need advice
I was trying to prep my del Sol's engine bay for repaint and engine swap. Well, most of my bolts and nuts were corroded (rusty) so I tried to remove various nuts and bolts for replacement.
Anyway, I was trying to remove the nut on the (brake) proportioning valve and SNAP, there's my nut (now essentially a bolt) with most of the 8mm threaded piece seized right in. I'm not sure if it's actually a stud because I don't think it unthreads from the other end. It looks like it's welded in there? I haven't removed my dash yet so I don't know what it looks like on the other side of the firewall.
Maybe I should have taken a die to the threads before attempting this but hindsight is 20/20. The threads were so corroded. The metal seemed kinda weak too.
What is the typical way to fix this? Weld something in its place like a bolt with most/all of it's head cut off? I can't weld... Replace the firewall? Probably too expensive for me but that'll clean up all the rust there... Drill out the threads and use a bolt on the opposite side? I'd have to have someone hold that steady while tightening the nut though... Or is there like a plate with threads on it that you slide in from the dash side? If so, part #?
Yeah, it will just stay there but the reason I'm in this forum is to repair it. I want to bring the car back to as close to new condition is possible as cheap as possible. If I could afford it, I'd buy a rust-free Del Sol from a hot/dry area.
Good luck with the heater core. Cut it off flush, tap a hole right through the middle of the broken stud, and use the next smallest thread pitch bolt or stud. Try a 6mm diam. You don't need it to be super strong since there is no load on the junction.
