Skunk2 Pro2 Question ?
Old Sep 12, 2007 | 07:13 PM
Jdmb16sir2's Avatar
Default Skunk2 Pro2 Question ?
Im running a
b16a stock bottom end
cometic head gasket( 11.5-1 comp)
arp head stud
supertech springs a reatainers
blox type a
inline cam gears
greddy header
itr exhaust
and i would like to know if i can run s2p2 cams in it without having piston to valve issues and if the compression is high enough for those cam. ( im getting them for a great price)
Old Sep 12, 2007 | 07:26 PM
Chris Tune's Avatar
Default Re: Skunk2 Pro2 Question ? (Jdmb16sir2)
get pro1's and call it a day u got no motor for pro2
Old Sep 12, 2007 | 07:32 PM
KYSI's Avatar
Nil Desperandum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jdmb16sir2 &raquo;</TD></TR><TR><TD CLASS="quote">Im running a
arp head stud
blox type a
inline cam gears
greddy header
itr exhaust</TD></TR></TABLE>
cometic head gasket( 11.5-1 comp)?? are you sure this is right?
Old Sep 12, 2007 | 07:40 PM
Jdmb16sir2's Avatar
Default Re: Skunk2 Pro2 Question ? (KYSI)
i checked on zealwerks before i went done and it came to like 11.4**-1. i got the thinnest one cometic makes.
Old Sep 14, 2007 | 03:20 PM
r1de4life's Avatar
skunk2 did it with headwork and 11.1-1 so im pretty sure it will work your just not going to make that much power.
Old Sep 15, 2007 | 08:02 AM
HAMOTORSPORTS's Avatar
Default Re: Skunk2 Pro2 Question ? (r1de4life)
WAY too small displacement and not near enough compression for the pro2's
Go with the pro 1's
Old Sep 15, 2007 | 04:43 PM
r1de4life's Avatar
Default Re: Skunk2 Pro2 Question ? (HAMOTORSPORTSUSA)
B16A DYNOTEST MULE ENGINE
81mm X 77.4mm 1.6L DOHC VTEC 11:1
Modifcations HP Gain TQ Gain Notes
STEP 1 • Skunk2 Custom Header
• Skunk2 Stage 1 Cams
• Skunk2 Custom Short Ram Intake
• Skunk2 Exhaust 165-&gt;190 110-&gt;115
STEP 2 • Skunk2 Pro-Series Intake Manifold
• Skunk2 Stage 2 or Pro 1 Cams
• S2 Valves, S2 Springs & S2 Retainers
• Skunk2 / Hondata ECU
190-&gt;218 115-&gt;126
STEP 3 • Skunk2 Ported Head
• Skunk2 Stage 3 or Pro 2 Cams
• Skunk2 Throttle Body
• Comp Ratio increased to 11:1 218-&gt;232 126-&gt;134
http://www.skunk2.com/Engine/i...=CSPB
Old Sep 15, 2007 | 11:26 PM
alterdcreations's Avatar
that has got to be on a engine dyno.....with alot more tricks than told.
Old Sep 25, 2007 | 03:17 PM
baynedo's Avatar
Default Re: Skunk2 Pro2 Question ? (alterdcreations)
i got the pro2s, skunk2 says that 11.5 to 1 is bare minimum... but zeal autowerkz calulator was way off. it said that i would have 11.9 to 1 comp and with my high comp valves i be in 12 to 1. but it was way off and i was accualy 11.3 to 1. i wound up haveing to thin my factory gasket to get my 12.5 to one comp. but before i thined out my gasket i had 11.6 to 1 with pro2s and i made 200 hp and that was way too low pro1 would have did way better stay away from the pro2s unless you goto 12+ to 1 comp.. and your displacement is way too small go to lsvtec or b20 and you will make way more power.
Old Sep 25, 2007 | 03:28 PM
b20beast978's Avatar
with that displacement your better off runnig the stage 2 cams. the pro 1's would still be touch for that motor. Get a 84mm sleeve with some 12:1 CR pistons and you will unleash some nice numbers!
Old Sep 25, 2007 | 03:56 PM
cartune network's Avatar
Default Re: (b20beast978)
pro2's will kill ur midrange power. and u really dont have enough comp to take advantage of the pro2's. pro 1's would be a much better choice in my opinion.
Old Sep 25, 2007 | 09:15 PM
baynedo's Avatar
Default Re: (cartune network)
also get a good header not a dc header but a rage header on a untuned b16 with the stage 2s i picked up power all across the rpm range with my rage header
fuel..
15
Aug 17, 2011 04:00 AM
psegs80
16
Dec 9, 2006 07:38 AM
BillB
13
Apr 14, 2004 10:36 AM
