Dyno: GT35r, Pump Gas
Old Sep 12, 2007 | 05:01 PM
Turbo-charged's Avatar
Default Dyno: GT35r, Pump Gas
ERL sleeved block
8.8:1 Wiseco pistons 84mm
Manley rods
crower springs/retainers
assembled by myself
bearing clearances by Sander
hondata S300
3 bar map
880cc injectors
3 inch DP/EX
exhaust manifold is a honda-tech company. wont say the name because it didnt fit AT ALL. made oil return nearly impossible, waste gate had to be cut off and relocated, would only allow for 2 inch charge pipe on hot side.
2.5 inch charge piing on cold side
edelbrock intake manifold
stock throttlebody
distributor didnt work right off the bat. changed it out with another and everything was good to go. boost and chart were wavy at first...found boost leak internal on throttlebody. fixed that.
car made a little over 400 whp at 20lbs. wasnt too happy....car just seemed like it needed bigger cams. i made some cam gear adjustments and re-synced ignition timing. picked up 35whp. dialing in ignitoin timing at the same boost level picked up nearly another 20.
car has no so awesome tires, doing pulls in 3rd gear started to develop some wheel spin once we got up in power.
will probably run the car in the 350-400whp range for daily driving. i have done several cars lately in the 450-475 range on pump that havnt had any reliability problems, however i do suggest keeping it around 400. nobody listens though
customers original power goals were 450whp. car should be a blast to drive.
Old Sep 12, 2007 | 05:08 PM
mighty137's Avatar
Nice #'s for a DD.......No race gas tune???
Old Sep 12, 2007 | 05:15 PM
blaze the chemi's Avatar
Default Re: Dyno: GT35r, Pump Gas (Turbo-charged)
B16? B18? Why did the customer want such a low CR? Still looks to be a blast as a DD once everything is checked out
Old Sep 12, 2007 | 05:23 PM
ZeremiaH's Avatar
Default Re: (mighty137)
OMG! 465!! I thought u said 457 on the phone. This is even better! Damn it Joe, why are you so good!! Since you made this engine great from the inside/out, now Jeff has to show off his talent with the valve cover, no pressure Jeff
Old Sep 12, 2007 | 05:39 PM
tony1's Avatar
Default Re: Dyno: GT35r, Pump Gas (blaze the chemi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">B16? B18? Why did the customer want such a low CR? Still looks to be a blast as a DD once everything is checked out </TD></TR></TABLE>
Because low compression ratio for a street driven car that sees pump gas 90% of the time is the smart thing to do...
Old Sep 12, 2007 | 05:50 PM
Boostfed's Avatar
New User
8.8:1 is the shelf stock piston from Wiseco for an 84mm B series , it is not low by any means, most people run 9:1 ish and you will not feel the difference between 8.8 and 9:1 anyways
Old Sep 12, 2007 | 05:51 PM
tony1's Avatar
Default Re: Dyno: GT35r, Pump Gas (Boostfed.com)
I use that exact piston on 90% of my street builds.
Old Sep 12, 2007 | 06:03 PM
DrivinVtec's Avatar
only 400whp on 20psi on a gt35? man. i have at3/t4 60 trim with .63 stg 3 wheel an people say i can get 400whp out of that. is that true?
Old Sep 12, 2007 | 06:04 PM
DrivinVtec's Avatar
i woulg bet better gas milage too when not in boost. it'll be turd thow. lol
Old Sep 12, 2007 | 06:19 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: Dyno: GT35r, Pump Gas (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">I use that exact piston on 90% of my street builds.</TD></TR></TABLE>
i would think a gt35 would have made more power at less boost on that motor.
i made 400 on a built ls SC61 on 19psi
i guess my 10:1's are no good then huh tony
Old Sep 12, 2007 | 06:27 PM
DrivinVtec's Avatar
Default Re: Dyno: GT35r, Pump Gas (tannerLSt)
thats what i thoght too. what u think my turbo will produce?(sorry to ask in someone elses thread)
Old Sep 12, 2007 | 06:43 PM
integranator's Avatar
Default Re: Dyno: GT35r, Pump Gas (DrivinVtec)
didn't he say that the number posted IS as 20 pounds?
Old Sep 12, 2007 | 06:49 PM
Granted my car never saw that power, it did see the road track and autox several times and I just took off my turbo setup at just under 20K miles. I never saw anything other than 93 octane and I boosted between 12-15 psi every day. I also have a 9.9:1 CR and it is still kicking and screaming as my DD.
I just wouldn't choose a lower CR motor as a DD because lag, but that is me. Thanks for your experience and wisdom answering my question.
Old Sep 12, 2007 | 07:34 PM
CustomX113's Avatar
Banned
car sounds strong
Old Sep 12, 2007 | 07:53 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged &raquo;</TD></TR><TR><TD CLASS="quote">
wow so someone on here is making and selling shitty manifolds and you wont even warn other people before they get screwed also??
Old Sep 12, 2007 | 10:34 PM
Cyber ITR's Avatar
i thought you'd be on the CP bandwagon
what pistons do you use on ur drag car ??
Old Sep 12, 2007 | 11:07 PM
Doostur's Avatar
Nice work
Old Sep 12, 2007 | 11:36 PM
V-SPEC 1's Avatar
Default Re: (Doostur)
Good job Joe
Old Sep 13, 2007 | 03:34 AM
sc4dr's Avatar
Default Re: (V-SPEC 1)
kinda looks similar to my power curve Joe. I bet he can't get traction for *****.
Old Sep 13, 2007 | 04:02 AM
DaveF's Avatar
Tempest Racing, crankin cars out !!!
Old Sep 13, 2007 | 04:56 AM
tony1's Avatar
Default Re: Dyno: GT35r, Pump Gas (Cyber ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cyber ITR &raquo;</TD></TR><TR><TD CLASS="quote">
what pistons do you use on ur drag car ??</TD></TR></TABLE>
I use JE in my drag car.
Old Sep 13, 2007 | 05:57 AM
MeanGreenMachine's Avatar
good job to tempest racing!
id like to know the company that made the manifold, if youd like, please PM
Old Sep 13, 2007 | 06:01 AM
Default Re: Dyno: GT35r, Pump Gas (rota92)
yes these are the shelf stock wiseco pistons that we use in every turbo street motor we do.
the reason i dont want to name said brand is i didnt buy it and i dont know the customers relationship with the company. also, i assume this is one of their older manifolds b/c what i have seen from their newer stuff, it seems a lot better. if he wants to bring the manifold maker into it than he can, but the second that happens this thread becomes worthless and it will be 34 pages long of this manifold vs. that manifold. the biggest problem with the manifold is you can tell it was built on an engine stand.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi &raquo;</TD></TR><TR><TD CLASS="quote">I just wouldn't choose a lower CR motor as a DD because lag, but that is me. Thanks for your experience and wisdom answering my question.</TD></TR></TABLE>
no difference in lag with low compression, just slightly less power off boost. 35r on an 84mm doesnt have that problem. as you see in the charts peak boost is reached at 5500-6000 rpm or so, but if you hit the gas at 3k the car still has *****. i really like 35r's on street cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">
i guess my 10:1's are no good then huh tony </TD></TR></TABLE>
so another 70 horsepower with 1 lb of boost isnt good? i think with a set of cams we could get the car into the 450 range with a few less lbs of boost. a throttlebody wouldnt be a bad idea either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">kinda looks similar to my power curve Joe. I bet he can't get traction for *****.</TD></TR></TABLE>
if it wont hook on the dyno, it surely wont hook on the street!! the car will probably be faster in the 15lb of boost range. the cars still strapped on the dyno right now, we are using s300 for boost controll so i'll set it up with differnt boost in each gear which should help.
cars like these make me want to build another street car for myself stupid race car lol
Old Sep 13, 2007 | 06:39 AM
.CUBISH.'s Avatar
awesome..very similar to my last street car
Old Sep 13, 2007 | 08:36 AM
Boner_Ben's Avatar
Default Re: Dyno: GT35r, Pump Gas (.CUBISH.)
