NEED HELP ON DPFI-> MPFI 91 CIVIC DX
Doing a b16 SWAP into a 91 CIVIC DX I HAVE TO SWITCH IT OVER TO MULTI PORT INJECTION. IS THERE A EASY WAY OR DIAGRAM. I HAVE FOUND THIS BUT IS IT 100% CORRECT.
http://www.angelfire.com/d20/h....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tmaxxkretchy »</TD></TR><TR><TD CLASS="quote">BE PREPARED FOR WHAT. Ive got a HONDA TECH DOING THE WIRING OFF THE DIAGRAM i work AT HONDA AS WELL.</TD></TR></TABLE> Wiring can be tricky for those not used to it, is what Tyler meant.
If you both know what you are doing MPFI is a snap.
Best of luck
Best of luck
So all i have to do is WIRE in V-tec and Multi port to make my b16 Work.... I am using a 1991 dx honda civic hatchback........ or is more involved?
well you are prepared and you have a honda tech doing the wiring and you work for honda so why are you asking..... there are multiple write ups on MPFI conversions. Heres the ones I used. The difference for you is wiring in the vtec rest should be the same
http://www.geocities.com/teamp...20071
http://www.50mod.com/fourthgenhatch/mpfi.html
shallam
Apr 15, 2012 01:57 PM
jmoney1698
Jan 10, 2008 01:16 PM
EF_p1n0y_b0y
Jan 16, 2004 05:41 PM
seditiouscivic
May 5, 2003 01:36 AM
