92 Prelude brakes on a 5th gen accord?
Old Sep 12, 2007 | 04:32 PM
scootibum's Avatar
Default 92 Prelude brakes on a 5th gen accord?
Will the rotors and breaks from a 92 Prelude bolt right up to a 94 Accord sedan? My friend is about to do a H22 swap on a 5th gen accord and we were wondering if this could be done.
Old Sep 13, 2007 | 04:17 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: 92 Prelude brakes on a 5th gen accord? (scootibum)
Check some of the brake swap links in the FAQ for info on what parts are needed, what will work and what wont.
Old Sep 13, 2007 | 11:26 AM
scootibum's Avatar
Default Re: 92 Prelude brakes on a 5th gen accord? (TouringAccord)
k, thanks alot man
Old Sep 13, 2007 | 03:00 PM
timmy0tool's Avatar
yes it will bolt up if you swap over the hub, rotors, and calipers. that requires pressing the hub out of the knuckle which is a pain. i would upgrade to prelude if the donor prelude is a vtec model (bigger rotor and caliper). other than that the only benefit when going with prelude brakes setup is for the hub over rotor design for ease of replacing the rotors.
if you don't understand what i'm saying do more research or don't do it at all.
H22_aCCoRd_07
Aug 21, 2009 11:30 PM
themurrell
Jul 7, 2007 08:19 PM
hb_guy
Feb 28, 2007 06:48 PM
khunt0012
Feb 20, 2006 08:44 AM
Knightmare69
Dec 5, 2005 01:13 PM
