vtec
Old Sep 12, 2007 | 04:26 PM
92nahatch's Avatar
Default vtec
i have an lstec. when i got it v tec worked. i got a rev lim put in but a non certified man.... now vtec doesnt work it has oil i re wired vtec changed selinoids grounded it chnged ecus i dont know what could be wrong.
Old Sep 12, 2007 | 05:10 PM
Ron454321's Avatar
Have you recieved any check engine lights? Starting there would be best. And please try to check your post for grammar, it was tough to read.
Old Sep 12, 2007 | 07:31 PM
92nahatch's Avatar
Default Re: (Ron454321)
sorry about my grammar. no i am not throwing any codes.... i was throwing a tps code,but then i put on a stock tb and that solved the code... i dont know what els this could be
Old Sep 12, 2007 | 07:37 PM
MURDOCSgarage's Avatar
Default Re: (92nahatch)
check with the guy that chipped the ecu, he may have altered the vtec when doing the rev limiter.
Old Sep 12, 2007 | 07:59 PM
92nahatch's Avatar
Default Re: (MURDOCSgarage)
thas my problem i did ask him but he said he did nothing and i changed ecus and it still doesnt work.
Old Sep 13, 2007 | 01:54 PM
92nahatch's Avatar
Default Re: vtec (92nahatch)
b u m p
Old Sep 13, 2007 | 01:59 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch &raquo;</TD></TR><TR><TD CLASS="quote">b u m p</TD></TR></TABLE>
when you said that you rewired the solenoid, are you sure you wired it to the right slot on the ecu?
Old Sep 13, 2007 | 03:51 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92nahatch &raquo;</TD></TR><TR><TD CLASS="quote">i have an lstec. when i got it v tec worked. i got a rev lim put in but a non certified man.... now vtec doesnt work it has oil i re wired vtec changed selinoids grounded it chnged ecus i dont know what could be wrong. </TD></TR></TABLE>
Since your grammar was brought up, I'll clean it up so it's easier for others to read.
"I have an LS/VTEC. When I got it VTEC worked. I got a rev limiter put in, but by a non-certified man. Now VTEC doesn't work. It has oil. I re-wired VTEC, changed solenoids, grounded it, changed ECUs... I don't know what could be wrong."
Hope that helps you get answers. Plus this will bump the thread to the top again.
Old Sep 13, 2007 | 04:50 PM
Ron454321's Avatar
I'm sure if it wasnt wired correctly he would be showing another CEL though.
Old Sep 13, 2007 | 07:01 PM
92nahatch's Avatar
i wired it derectly to the ecu
2.2 teg
Jun 4, 2007 09:47 PM
bigdonnyboi
May 15, 2007 03:44 PM
xtreme-customz
18
Dec 1, 2005 07:51 PM
acdracing
Dec 13, 2004 06:13 PM
sk8phaze
Jul 28, 2003 07:44 PM
