unpinning ECU plug help!
Old Sep 12, 2007 | 12:21 PM
claytonsmith's Avatar
Default unpinning ECU plug help!
im either retarded or this **** is tricky... im starting to do the MPFI swap on a 88 dx... but i cant get the damned wires on the black (smaller) ECU plugs unpinned.. the larger white/clear plug is no problem
is there some sorta trick to this or a special Honda tool? i get that the top and bottom row of wires are depinned from a central hole on the plug thats in the middle of each "stack" of wires.. i just cant get the damn things to come loose
any suggestions?
thanks!
Old Sep 12, 2007 | 01:10 PM
IT GUY's Avatar
Default Re: unpinning ECU plug help! (claytonsmith)
https://honda-tech.com/zerothread?id=1573760
good thread on depinning and ECU plug..
I found this in the archives for this forum. Search is your friend
tkda
Feb 19, 2009 04:23 PM
hatchback_al
Nov 27, 2004 09:31 PM
shylilpimp
Oct 23, 2003 05:29 PM
