ZC harness
Old Jun 16, 2002 | 05:49 PM
slowman's Avatar
I took way too long
Default ZC harness
What kind of harness do i need for the ZC engine in a CRX?
Old Jun 16, 2002 | 05:56 PM
spettinger's Avatar
Default Re: ZC harness (SeeOurX)
you will need whatever harness comes in the car. if you don't have a car yet, buy an si and save a headache of wiring.
Old Jun 16, 2002 | 06:21 PM
slowman's Avatar
I took way too long
Default Re: ZC harness (wreckedhatch)
which swap would be easier? ZC or D16A6 and later on put on a Z6 head i want which ever one is the easiest
[Modified by SeeOurX, 11:28 PM 6/16/2002]
Old Jun 16, 2002 | 08:16 PM
*Boostwerks*'s Avatar
Buy an Si and put on a Z6 head is going to be by far the easiest swap.
then again, I wouldn't do that unless you had a good Si plateform to start with.
If your looking to swap in an entire motor...the ZC is by far the easiest. Don't even consider the B16 if your looking for easy wiring, and cheep overall swap.
Old Jun 16, 2002 | 08:27 PM
slowman's Avatar
I took way too long
Default Re: ZC harness (Bryson)
I was planning on buying an HF because theyre cheaper and then putting the Si engine in it and then the z6 head. would this not be smart to do??
The Destroyer
11
Dec 30, 2005 02:22 PM
Babybluegsr92
Jun 26, 2002 04:27 AM
slowman
Jun 17, 2002 11:55 AM
vtec_head
May 8, 2002 08:59 AM
