JDM climate control
hi, im from the uk, there is a JDM civic in my local scrappy, i have searched for this and everyone says change the face plate and bulbs, but i dont want to, i want to do the proper swap as its all there. what i would like is a list of all the parts needed to swap it in properly and have everything working. the reason i want to do this is because i have pretty much got every part from an import on my car so this is nearly the last thing to complete my full jdm car.
i know i need the climate control, but do i need the whole heater matrix? and the wiring, fusebox etc?
converting to a fully electronic climate control from a JDM model would require you taking apart your dashboard and the same with the donor car afterwards swapping everything over assuming its in proper working order. its alot of work and the best reward is if anything goes wrong with your JDM ac you would have to buy a replacement part from japan for that electronic climate control.
