spindle ques...
how can i tell if the bearings on my spindle or halfht is bad.....
got a eg coupe with itr swap with lsd....
when i get on it or when i turn driver side tire feels like if it loose...
thanx..
thanx..
make sure the tire isn't actually loose?
Jack the car up and wiggle the wheel at the top and bottom, then side to side...if you feel play then have someone shake it for you while you look to see what the problem is
Some things to look at:
Upper ball joint
Lower Ball Joint
Wheel bearing (if the axle moves but nothing else does)
Suspension bushings (control arms)
Inner Tie Rod
Outer Tie Rod <- tough one to catch sometimes but is very rare to go bad.
Upper ball joint
Lower Ball Joint
Inner Tie Rod
outter tie rod was replace two moths ago.... upper ball joint is a camber kit...
just got thru replacin my axle since the theeth were all messup.... axle wont go all the way in the halfshaft and there's lots of play when put everything back together( axle and half shaft).... can it be the halfshaft???????
2camsaam
Oct 6, 2003 03:10 AM
Propulsion
Aug 3, 2002 08:52 AM
GruvyTune
Jul 22, 2002 10:01 AM
