alternator to ecu fuel saving
Old Sep 11, 2007 | 06:25 PM
aojtin's Avatar
Default alternator to ecu fuel saving
well on my 88 crx it has the lights dim when i let off the gas thing so is there a wire i can cut from teh alternator to the ecu to jsut have the alternator putting out its fuel volts at all time. you have to do that anyway to upgrade to obd1 right?
Old Sep 11, 2007 | 07:19 PM
2slow4stock's Avatar
what?
Old Sep 11, 2007 | 07:31 PM
ej8's Avatar
ej8
Default Re: (2slow4stock)
Sounds like you have a weak alternator or bad engine ground. Fix the problem, don't rig it up....
Old Sep 11, 2007 | 07:43 PM
Crx Jimmy's Avatar
Default Re: alternator to ecu fuel saving (aojtin)
its normal for the lights to dim slightly with a load on at idle. dont worry about if. unless your battery isnt charging leave it alone. and no you can use the ELD with obd1
wspencer5
Honda Civic (2001 - 2005)
Jan 3, 2015 02:10 PM
sameb
Engine Management and Tuning
Aug 3, 2011 07:08 AM
agp1183
Feb 15, 2008 03:10 PM
C-A
Oct 1, 2007 07:17 PM
Gump
Sep 29, 2004 08:16 PM
