paint pros.. i need your help!!
Old Sep 11, 2007 | 05:56 PM
SwapedEX's Avatar
Default paint pros.. i need your help!!
ok, well i have decided to paint my car myself..and i need a few questions answered.
the colors i have to decided between
1. voltage blue met - year 2000 honda
color chip formula 5635
mfg pnt cd b97m-s
2.vivid blue pearl - year 2003 honda
color chip formula 6176
mfg pnt cd b520p-u
now i have a 94 hatch, i plan on painting the car obviously, and the door jambs and engine bay.
now how much paint do you think i will need? 2 gallons? and what hardner and reducer? how much of each? how much clear? what are the mix ratios? i planned on spraying as a acrylic enamel. are there are pros or cons between the colors, as in spray technique?
all of my information was located from this web site..
http://www.tcpglobal.com/autocolorlibrary/
any and all help would be greatly appreciated!! thanks in advance!
Old Sep 11, 2007 | 06:17 PM
heyitzspikey's Avatar
Default Re: paint pros.. i need your help!! (SwapedEX)
1 gallon will be good enough should make around 1 1/2 gallon after mixing it with the reducer tell them you want a kit will make it alot more easy on you
Old Sep 11, 2007 | 06:21 PM
SwapedEX's Avatar
so 1 gallon should be enough to cover the entire car and bay? how many coats do u think? im trying to make this paint last.. planning on spending the money.. not like those fools with the $50 paint job lol
Old Sep 12, 2007 | 06:32 PM
michaelhinkle's Avatar
Default Re: (SwapedEX)
fools? have you seen some of those jobs? some of them are really good.
don't be so jugemental and grow up with the name calling.
Old Sep 12, 2007 | 07:14 PM
SneezinCD5's Avatar
I just did a color change on my brothers EG. Painted it Midori Green. Complet change, interior,bay evrything and use a almost 2 gallond sprayable. And use about a gallon of clear. I used PPG products
Old Sep 12, 2007 | 07:20 PM
SwapedEX's Avatar
Default Re: (michaelhinkle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelhinkle &raquo;</TD></TR><TR><TD CLASS="quote">fools? have you seen some of those jobs? some of them are really good.
don't be so jugemental and grow up with the name calling. </TD></TR></TABLE>
not that they are fools.. i just dont like how they turn out all flat looking.. its a great idea if ur on a budget...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SneezinCD5 &raquo;</TD></TR><TR><TD CLASS="quote">I just did a color change on my brothers EG. Painted it Midori Green. Complet change, interior,bay evrything and use a almost 2 gallond sprayable. And use about a gallon of clear. I used PPG products</TD></TR></TABLE>
how many coats did u spray?
Old Sep 18, 2007 | 05:48 PM
baggedSIcivic99's Avatar
if you buy ppg deltron paint 1 gallon should be enough the mixing ratio is 1 to 1 so that will give you 2 gallons
SwapedEX
Sep 11, 2007 05:55 PM
TNRspeed
Paint and Body
May 4, 2007 05:51 PM
94gsr18kid
Jan 24, 2005 04:02 PM
