1st gear is like an earthquake!!
Old Sep 11, 2007 | 05:33 PM
SoyMilk's Avatar
Default 1st gear is like an earthquake!!
Modified by l2al3l3it at 4:59 AM 9/17/2007
Old Sep 11, 2007 | 06:06 PM
SoyMilk's Avatar
Default Re: 1st gear is like an earthquake!! (l2al3l3it)
not one tech :[!
Old Sep 12, 2007 | 05:36 AM
SoyMilk's Avatar
tehczz
Old Sep 12, 2007 | 01:34 PM
King V's Avatar
What do you mean by shakes? Like when you put a car in 4th at 5 mph shakes or like misfire shakes? Does it do it all the way through the rev range? Any noises? Difficulty putting it in gear?
Old Sep 12, 2007 | 06:20 PM
SoyMilk's Avatar
Default Re: 1st gear is like an earthquake!! (200kCivicSI)
Where did I say 4th gear is messed up... only 1st gear.
No noise. Kind of difficult to put it in 1st gear ( Kinda rough)
I mean shakes as in 1st Gear at low rpm and low mph (start up mph)
RPM between 0 and 2k it happens.
The shake is when your head bobble back and forth. Like your car is pushing forward then stoping then pushing forward again so your head wobbbles back and forth.
Old Sep 13, 2007 | 04:31 AM
King V's Avatar
I was using the 4th gear as a reference to help describe your shaking. I know 1st is messed in your car, i can read. Sounds like your synchro is no good, for starters. What condition is the clutch in?
Old Sep 13, 2007 | 04:41 AM
King V's Avatar
From reading the other post, sounds like you need trans work from drag racing. And a new clutch and flywheel. Just tear it open and see whats wrong.
Old Sep 13, 2007 | 06:29 AM
SoyMilk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 200kCivicSI &raquo;</TD></TR><TR><TD CLASS="quote">From reading the other post, sounds like you need trans work from drag racing. And a new clutch and flywheel. Just tear it open and see whats wrong.</TD></TR></TABLE>
hmm what should I look into ? The transmission? or the Clutch/Flywheel.
Old Sep 13, 2007 | 08:24 AM
King V's Avatar
Well both. First is Probably worn real bad, since you said its hard to get into first, but had no problems with the other 4 gears.
Old Sep 13, 2007 | 12:09 PM
SoyMilk's Avatar
thats true, if its hard to get in 1st gear how do you fix that?
Old Sep 13, 2007 | 12:31 PM
King V's Avatar
If it was me, I would replace the gear cluster and the synchro as a set, and since you're opening the trans, i would replace the roller and ball bearings on the input and output shafts. A competent trans shop or dealer should be able to do it for you. I wouldn't touch the insides of a stick, cause its too many shims and clips for my big *** fingers. And last i heard, to do the bearings themselves is a $600 job, dealer price. I would check your clutch situation first if you can rip off the trans yourself, and it will save you on labor if you need to dig into the trans since you took off the trans yourself.
Flip's DC5
39
Oct 15, 2007 10:17 AM
jdm_DC2R
Mar 21, 2006 08:37 AM
f1 vtec
Jun 9, 2004 09:17 AM
vicz
Apr 17, 2003 06:38 AM
TypeR01-424
Nov 26, 2001 12:31 PM
