help engine redlined at 7000 rpms instead of 8000 rpms????
Old Sep 11, 2007 | 04:26 PM
EG_LS's Avatar
Default help engine redlined at 7000 rpms instead of 8000 rpms????
i was going to redline it an my engine stoped at 7000 rpms instead of 8000, why is that ???? it did it in first an then 2nd gear an then i stoped an did it again but it was fine the second time(8000rpms redline) this is on my crx jdm b16 thanks for help
Old Sep 11, 2007 | 04:36 PM
Crx Jimmy's Avatar
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (EG_LS)
was the motor still cold?
Old Sep 11, 2007 | 04:42 PM
EG_LS's Avatar
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (Crx Jimmy)
i used it to go to work an then after an then it sat for like 3 hours an then thats when i got in it an used it an it happened
Old Sep 11, 2007 | 05:07 PM
garageEF's Avatar
let your car warm up completly then try again. sounds like the cold rev limiter to me...
Old Sep 11, 2007 | 05:13 PM
EG_LS's Avatar
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (garageEF)
its fine now it was fine the second time i tried it so it was the cold rev limiter then???
Old Sep 11, 2007 | 05:27 PM
STREETWERKZ's Avatar
good job beating up your motor when its not fully warmed up there buddy.
use your noggin.
i have the feeling, that you didnt warm up your noodle before reading an english book either. because your **** isnt firing on all cylinders.
Old Sep 12, 2007 | 05:35 PM
EG_LS's Avatar
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (STREETWERKZ)
what a dick, the car had been running since morning, and this happend at noon so im pretty sure it was warmed up!!!
Old Sep 12, 2007 | 05:43 PM
gator88's Avatar
he can be a slight dick, but he is an extremely knowledgeable honda enthusiast who many around here have learned great info from. I would take that info and run, consider what he said and move on. if ur car sat three hours like you said, then no it wasnt warm all the way no matter what ur little guage said.
edit: he probably means that you forget the "d" in AND, some people appreciate proper word usage, since that is a completely different word. Internet slang/abbreviation is okay, but it has to mean the word you are intending to use. Just a thought
Old Sep 12, 2007 | 07:28 PM
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">
edit: he probably means that you forget the "d" in AND, some people appreciate proper word usage, since that is a completely different word. Internet slang/abbreviation is okay, but it has to mean the word you are intending to use. Just a thought </TD></TR></TABLE>
no, it's a little bit more than that. but, that's a start.
if it WAS fully warmed up, my second guess would be oil pressure.
Old Sep 13, 2007 | 02:55 PM
EG_LS's Avatar
sometimes it feels like its laging it an then the power just bumps back on why would that be??? this happens in low rpms like from 3rpms an up,(when im driving normal)any clue what it could be or is that from the oil presure too?
Old Sep 13, 2007 | 02:59 PM
when was the last time you did an oil change? what is the oil level at?
Old Sep 13, 2007 | 03:22 PM
EG_LS's Avatar
the oil change was done about 2000 miles ago an the level is right were its suppose to be, i changed the spark plugs yesterday.
Old Sep 13, 2007 | 03:23 PM
jdm_titan's Avatar
my respects to "STREETWERKZ" he knows what he is talking about
Old Sep 13, 2007 | 03:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_LS &raquo;</TD></TR><TR><TD CLASS="quote">the oil change was done about 2000 miles ago an the level is right were its suppose to be, i changed the spark plugs yesterday.</TD></TR></TABLE>
when did you check the oil level?
have you checked the spool valve screen in the vtec solenoid?
Old Sep 13, 2007 | 03:34 PM
EG_LS's Avatar
the last time i checked the oil was yesterday an it was full, should i check the spool screan on the vtec silenoid even do it lags it before hiting vtec? dont you think its probably something else or both?
Old Sep 13, 2007 | 03:45 PM
everything you check and fix would be beneficial. dont just assume the screen is clean.
Old Sep 13, 2007 | 03:49 PM
EG_LS's Avatar
okay were exactly is it? an what does it look like? im not familiar with it bro?
Old Sep 13, 2007 | 03:50 PM
you've never seen a vtec solenoid? take it off, replace the screen/gasket.
Old Sep 13, 2007 | 03:51 PM
Hamstr323's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_LS &raquo;</TD></TR><TR><TD CLASS="quote">what a dick, the car had been running since morning, and this happend at noon so im pretty sure it was warmed up!!!</TD></TR></TABLE>
ummm so you're saying it's not possible to get cold after 3-4 hrs because it was noon? umm yes it is possible
Old Sep 13, 2007 | 05:31 PM
.Grimace's Avatar
footwork mastery
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (Hamstr323)
streetwerkz is a feg haha no proper english here
but on a serious note i'm going to agree with him and say it wasn't fully warmed up. you said it sat for three hours.
Old Sep 13, 2007 | 05:33 PM
Default Re: help engine redlined at 7000 rpms instead of 8000 rpms???? (Gremice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gremice &raquo;</TD></TR><TR><TD CLASS="quote">streetwerkz is a feg haha no proper english here
you fat purple bastard.
Old Sep 13, 2007 | 05:36 PM
.Grimace's Avatar
footwork mastery
you fat purple bastard. </TD></TR></TABLE>
haha... i'm too easy of a target
Old Sep 14, 2007 | 02:36 PM
EG_LS's Avatar
the gasket was good what else could it be???? my rpms idle at 1500 an drop to like 500 rpms and it goes back to 1500 an drops it does it continously when its sitiing still. any ideas??????????
Old Sep 14, 2007 | 02:47 PM
B16A CRX's Avatar
that can probably be your tps
Old Sep 14, 2007 | 02:51 PM
EG_LS's Avatar
Default Re: (B16A CRX)
tps????? what you mean by that????
